Old 23-03-2008, 02:12 PM   #1 (permalink)
jal_desai's Avatar
Default They say my ADSL LINK has some problem....
BSNL BROADBAND. They came and installed it one week ago. I used it tht day and by night the connection lost... IT NEVER CAME BACK AGAIN i called them. After a 100 calls they picked up the phone... and i told them my problem but they werenot able to give a satisfactory reply... i said tht the DSL light on the MODEM is blinking continuously... The only thing they said is tht THE DSL LIGHT should glow continuously and I had the problem with my ADSL LINK... i wanna ask... HOW?? WHERE THE PROBLEM IS? MY PHONE WORKS FINE..? IS THERE ANYTHING I CAN DO WITHOUT WAITING FOR THOSE DUMBOS?
TechExplorer.in
jal_desai is offline
Old 23-03-2008, 02:22 PM   #2 (permalink)
Stalker's Avatar
Default Re: They say my ADSL LINK has some problem....
Are you using dedicated phone line for the modem? First, try disconnecting all the phones & connect ONLY the modem. See if the light comes on.
Otherwise check your DSL Modulation Options in the modem.
| C2Q Q6600 G0 | Intel DG33FB | 4 GB Corsair 6400C5G DDR2-800Mhz | XFX 8800GTX | CM Extremepower 600W | 250GB Seagate HDD | Lite-ON 1635S DVD RW | Logitech MX-518 | Zalman RS6F | APC RS 800 |
Stalker is offline
Old 23-03-2008, 03:03 PM   #3 (permalink)
jal_desai's Avatar
^^ "DSL Modulation Options" .... How to check them?.. I connect my modem and the LAN STATUS show connected at 100 mbps... i open up 192.168.1.1 for my modem options... i give my username-password but there's written on tht screen "YOUR ROUTER IS NOT READY TO CONNECT"... any idea?
see screen shot below:
i feel tht no one has faced this problem.... Any answers doston..? i am dying to download lotsa stuff....
TechExplorer.in
Old 23-03-2008, 03:36 PM   #4 (permalink)
dig_boy_dig,dig !
skghosh44's Avatar
BSNL normally provide UTSTAR Modem(DSL) and in the modem there are 5 LED 1) power 2) DSL/ADSL 3) Internet 4) Ethernet/LAN 5)USB
Now switching on the System as well as the modem the no 1)power LED will glow if the DSL/ADSL line is OK after 2 mnts it will glow constantly and the other two LED ethernt and internet will blink when you connected to the net. If not connected to the net the ethernet LED glows constantly and the internet LED is off.
Now check what is in your case. If on successful connection to BSNL server you cannot open web page it might be causing due to firewall setting.
Also sometime I found On successfull connection to BSNL server the web page not opening, on enquiry from BSNL they told me that ther is some problem whith ther server. After a few mnts/hour it is allright.
fower failur at my end. see u again
________________________________________________
I like signature after 10 P.M.
skghosh44 is offline
Old 23-03-2008, 04:00 PM   #5 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
The link is blinking continuously because BSNL has changed the DSL syncing mode and your modem might be forcing another.
It can also be that the phone line has acquired noise.
Harvik780 is offline
Old 24-03-2008, 11:24 AM   #6 (permalink)
Point Blanc
I hope you know the nos for BSNL Customer Care, also check with the JTO of the Telephone Exchange near you giving you the connection, ask them to send someone to check your ADSL router.
Most probably its inital problem they wouldnt have configured it properly, same thing had happened to me after 2 days it had stopped working, then I had called up about a week or 10 days later and they had checked on their side. It became fine. BTW what is the router's login n pass set for you, those guys didnt gave me, so I cannot check my router on my own. have alwas to restart it manually power on/off
acewin is offline
Problem with DLink ADSL 2/2.0+ 2640-T abhinav_bipnesh Hardware Q&A 6 13-09-2007 02:57 PM
Problem with OS/ADSL Modem/Net Connection??? go4saket Networking 8 26-08-2007 02:23 PM
ADSL getway problem Choto Cheeta Hardware Q&A 11 26-11-2005 01:42 AM
- by c4u
