I want to connect to internet using youtele cable connection .What i did is
I selected
1.Create new connection wizard
2.Connect to internet
3.Set up my connection manually
4.But here "connect using a dial-up modem " and "connect using broadband (2 option) "are not active.I cannot select those two though i have to select the first option.
Help me plz
Sometimes some services dont start up for connection so try lookin 4 that . . Go thru help n support . . . Coz i had the prob with mobile conn too there was no telephony service . . . N modem settings if detect or not . .
Om Ma Ni Pä Me Hum: (perfection of-)
Om: generosity,- Ma: pure ethics,-Ni: tolerance n patience.- Pä: perseverance,- Me: concentration,-Hum: wisdom... Using Opera Mini Airtel NOP
