Old 22-03-2008, 07:20 PM   #1 (permalink)
Default My Pc need some suggestions
Hello every1 (my first post here )
okies here goes
this is my current configuration
Pentium (D) dual core 2.66 (533 fsb )
Intel 965 ryck mobo
1Gb x 2 Transcend Ddr2 ram (800 Mhz)
160 gb hdd sata
80 gb hdd
Sony Dvd-RW
xfx geforce 8800 gt alpha dog editon (512mb)
Vip 400W Psu
okies i know many of the things look mismatched (probably cause i bought them seperately,as per availability of cash )
wht i wanna know is,
1) how would you rate this system?
2) Wht all do you think i need to change?? and according to you what should i think about upgrading first?
3) Would it be possible to overclock this mobo to get faster fsb (seeing as how all core2duo are 1333mhz ) if yes, could some1 please explain how or point to a link that will assist me
fuzzz is offline
Old 22-03-2008, 07:24 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: My Pc need some suggestions
Reported........
ravi_9793 is offline
Old 23-03-2008, 10:27 AM   #3 (permalink)
darklord's Avatar
Why report the post ?
@ Fuzz,
1] You havent mentioned model of your motherboard,without that it is impossible to answer your Overclocking related questions.
2] Your system looks decent
3] You need a better power supply, that 400W is not going to pull off the load from 8800GT and other stuff, instead of risking all your hardwre, get a better power supply.
darklord is offline
Old 23-03-2008, 11:04 AM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
Because earlier the post was having some links.
Old 23-03-2008, 02:40 PM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
if u can then u sud upgrade ur procy to C2D or C2Q depending on ur pc usage.
hellgate is offline
Old 24-03-2008, 06:04 PM   #6 (permalink)
Well ravi, i didnt know that the link would get included automatically..
i had posted this same thing on another forum.. and insted of typing it all again,i chose to copy paste.. an seeing as how that was my first post i would have expected a old member like u to explain wht my mistake was(It was my first post here... any ways i got the message)
@dark Lord
its an intel 965 ryck ... i do hope something can be done about it..
err really, that 400W wont be enough ?? Bah! i just purchased it recently... dats more money down the drain ...
@hell
yeah i want to upgade procy,but cant do that unless i can get my fsb up to 1333...
fuzzz is offline
Old 24-03-2008, 06:21 PM   #7 (permalink)
ancientrites's Avatar
definately processor must be upgraded ASAP.
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
ancientrites is offline
Old 24-03-2008, 10:10 PM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
u cant oc with that board cuz it doesnt support oc.Intel original mobos dont support oc.
so ur best bet is to get a new chipset based mobo whihc supports oc and a new C2D or C2Q and then oc the hell out of the procy..
hellgate is offline
Old 25-03-2008, 06:17 PM   #9 (permalink)
Oh man this sux...
so what mobo would you suggest i go in for ?
any1 intreseted in buying a fairly new intel 965 ryck board??
fuzzz is offline
Old 25-03-2008, 08:10 PM   #10 (permalink)
darklord's Avatar
Abit IP35-E for ~ 5.5k
darklord is offline
Old 25-03-2008, 08:30 PM   #11 (permalink)
ramsingh's Avatar
does 5.5 K include VAT ??
INTEL Q-6600, Abit IP35-E,2X 1 GB Transcend DDR2(800Mhz),MSI 9600GT 512MB, 200GB Seagater HDD,17" Samsung 798MB Plus,Pinncale Stereo TV card,Dataone-H500...
ramsingh is offline
Old 25-03-2008, 08:38 PM   #12 (permalink)
darklord's Avatar
yes, this price is going on in mumbai, kolkata and some other places, in pune though its still 5700-5800 or so, dont know why.
darklord is offline
120 gb Ext.HDD , suggestions please anish_sha Hardware Q&A 14 23-01-2008 01:20 PM
PMP Suggestions within 8k max.... gauravakaasid Buying Advice 25 21-01-2008 01:44 AM
ur suggestions plz! xsreality Hardware Q&A 17 27-03-2007 08:24 AM
Suggestions for a new PC Yamaraj QnA (read only) 16 25-05-2005 06:35 PM
- by c4u
