Old 21-03-2008, 09:53 PM   #1 (permalink)
Smile Usb Probs!!
hey.....
dunno y all ov a sudden all my usb interfaced equipments hv failed 2 wurk....
neither does d pc recognize it nor does d led lite up!!!
so kindly advice me accordingly! n dis is like all ov a sudden aite! hve tried all kinda software solutions!!!
Waitin fer responses.... Thnx in advance!
~PunK~ is offline
Old 22-03-2008, 07:17 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Usb Probs!!
Uninstall all of your usb peripherals drivers first.Uninstall all of your USB controllers from device manager and restart your computer. Your usb controllers drivers should be re installed. Install all of your usb peripherals drivers again.Your problem shoud be solved.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 22-03-2008, 07:29 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
This may help you.
Unrecognized USB Device Problem
ravi_9793 is offline
Old 25-03-2008, 01:40 AM   #4 (permalink)
ohh....
thnx buh den ive tried all d above solutions lyk a hundred tyms....
buh it actully is nt dat d usb devices r unrecognizabl buh its sum prob wid d usb ports......dat is d onboard 1s.....
so plese advice me further.....
thnx 2 all repliers.....
~PunK~ is offline
Old 25-03-2008, 07:42 PM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
Clean ur onboard usb ports or else buy a new usb pci card ie a pci card that has 4 to 6 usb ports. Should be available for below than Rs. 500.
topgear is offline
Old 27-03-2008, 01:06 AM   #6 (permalink)
Smile Re: Usb Probs!!
aite.... thnx a ton topgear...
guess ur adea shud wurk.....
buh nywayz i don reside in india....
shud manage it nywayz....
buh do u noe wat cud b d possible reason...
all ov a sudden it ju stopped werkin....
nywez thnx a ton....
!PeacE!
~PunK~
~PunK~ is offline
Help me Out with my probs !! coolboy_n QnA (read only) 6 17-04-2007 04:52 PM
N70 probs.... sam_1710 Mobiles and Tablets 12 28-10-2006 07:46 AM
net probs in qd montsa007 Mobiles and Tablets 1 27-05-2006 01:14 AM
C++ probs... legolas Open Source 2 01-05-2006 07:34 PM
probs that never end navisangha QnA (read only) 3 26-09-2005 08:02 PM
- by c4u
