Old 21-03-2008, 07:34 AM   #1 (permalink)
Subbu loves Technology
sravan's Avatar
Smile Internet sharing
I have a Youtele cable internet connection
I want to share it between 2 sys
Is it possible with using any switch or hub?
sravan is offline
Old 21-03-2008, 12:31 PM   #2 (permalink)
mekalodu
iinfi's Avatar
Default Re: Internet sharing
yes you can ...
if you are gona use only 2 PCs then a switch or a hub mite be costly.
u can use 2 LAN cards on one PC (one for Youtele cable to come in and the other heading to your other PC) and one on the other to share the internet connection.
if you are using the above config. then you will have to keep the main/server PC on when you need net on the other PC.
if you are planning to expand then use a hub/switch.
let us know if you have further queries
mekalodu
iinfi is offline
Old 21-03-2008, 01:39 PM   #3 (permalink)
sravan's Avatar
Smile Re: Internet sharing
Thank u for ur reply
How much a LAN card costs?
sravan is offline
Old 21-03-2008, 01:43 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
approx 200-300 rs
Blogging at:
Technostarry
saqib_khan is offline
Old 21-03-2008, 01:45 PM   #5 (permalink)
sravan's Avatar
thank u
sravan is offline
Internet sharing........ latino_ansari Internet & WWW 2 29-10-2007 10:49 PM
Internet sharing help me . RajuTiwari Internet & WWW 4 05-12-2006 07:42 PM
Internet sharing? LEARNER_LEARNER Software Q&A 6 14-11-2006 11:44 AM
sharing internet hunk_freak Tutorials 1 29-12-2005 11:23 AM
- by c4u
