Old 21-03-2008, 12:24 AM   #1 (permalink)
Default Abit IP35-E mobo booting problem
I just got my new rig:
1. C2D E4500 CPU
2. Abit IP35-E
3. Corsair 2GB dual channel RAM at 667MHz
4. My old Samsung 40GB IDE
5. VIP 400Watts PSU (Gold)
Many times when I start the machine (cold boot), It sometimes doesn't boot at all (with CPU fan spinning and LEDs on mobo lighted) or sometimes it gets double boot. I have updated my BIOS to version 15 (from 14), still problem continues. Anybody experiencing same problem...?
parimal is offline
Old 21-03-2008, 12:44 AM   #2 (permalink)
j1n M@tt's Avatar
Default Re: Abit IP35-E mobo booting problem
^^it might be ur Gfx card display problem......
BTW......wat do u mean by "double boot" ??!!
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 21-03-2008, 09:50 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
abit IP35-E does double post.i'm using the latest bios v16 beta and in this version abit has solved this double post prob.
hellgate is offline
Old 21-03-2008, 02:51 PM   #4 (permalink)
Yeah, I have flashed my BIOS to v16. But the problem remains the same. Any other solution to this??
parimal is offline
Old 21-03-2008, 02:58 PM   #5 (permalink)
slugger's Avatar
how often does the problem occur?
is ur monitor an old CRT?
my 15" sumtimes causes this - everything runnin once i start the comp but no display
i just switch off the mains and switch it back on after around 30seconds
the problem arises once a week or so
slugger is offline
Old 21-03-2008, 10:33 PM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
hav u oc'd ur procy?
hellgate is offline
Old 21-03-2008, 11:36 PM   #7 (permalink)
I haven't OCed my PC. But my monitor is Samsung SyncMaster 793DF CRT.
parimal is offline
Old 22-03-2008, 12:56 AM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
r u getting any specific type of bios beeps when ur pc is not booting?
hellgate is offline
Old 22-03-2008, 11:12 AM   #9 (permalink)
After flashing BIOS to v16, I haven't seen that PC is not booting at first shot. But double booting problem remains the same.
parimal is offline
Old 22-03-2008, 06:16 PM   #10 (permalink)
Any suggestion guys??
parimal is offline
Old 22-03-2008, 07:23 PM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
Check Your Rams.
My Old Pc Also has booting problems coz of bad rams. Got new rams & my problems solved.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 22-03-2008, 10:13 PM   #12 (permalink)
spyingshadow's Avatar
my mobo used 2 switch between my gfx n d onboard gfx once in a while..
disabled d onboard n voila, all good
Cant catch vot ya cant see 8-)
spyingshadow is offline
Old 23-03-2008, 12:52 AM   #13 (permalink)
I don't think problem occurs coz of bad RAMs. Lot of guys using same Abit board has got same problem. And that board doen't have onboard gfx.
parimal is offline
Old 23-03-2008, 10:21 AM   #14 (permalink)
darklord's Avatar
This is not a RAM related issue.This is mostly a BIOS issue.I am not sure if this is the case but it can be a issue with the bios related to strap.Intel chipsets based boards, right from 975X used to shutdown and self start after you would OC, this happened because the system used to check what strap is being used.
This CAN be the issue but should be sorted with newer BIOS and there is no reason to worry i suppose.
darklord is offline
Old 25-03-2008, 01:32 PM   #15 (permalink)
does this mean i should not think of buying abit ip35 now
p_d5010 is offline
Old 25-03-2008, 06:10 PM   #16 (permalink)
darklord's Avatar
The Abit IP35-E is NOT a bad board and trust me, almost every board has niggling issues, how much it affects one is completely relative.
It is a solid,well built board and performs equally well,i see no reason why people should not buy it.
darklord is offline
ABit IP35-E parimal Hardware Q&A 2 21-02-2008 10:13 AM
Quick Look at ABiT IP35-Pro Choto Cheeta Reviews 12 11-02-2008 01:17 AM
Abit IP35-E + C2D E6600 taken for a freezing ride darklord Hardware Q&A 19 29-12-2007 12:57 PM
E6600 taken for a spin,now with Abit IP35 darklord Hardware Q&A 3 19-11-2007 09:42 PM
Abit Motherboard performance? monkey Hardware Q&A 3 01-11-2007 07:59 PM
- by c4u
