Old 20-03-2008, 07:32 PM   #1 (permalink)
mannuforall
mannuforall's Avatar
Question USB Pen Drive Problems
Hi!
I have a 2 GB moserbear usb pen drive, but now problem is that I'm unable to write and delete any file in usb drive. I was installed USB Lock Protect 2.5 and I feel this happens after this installation. But after uninstalling this problem is same. My usb drive works fine in another computer. Plz help me....
Sys Config: win xp sp2, 2.4 ghz, 512mb,
Also plz help me to partition my usb drive to create 2 partition. and how to password protect any of one partition.
I'll be a great thank full of all you members.
mannuforall is offline
Old 20-03-2008, 07:39 PM   #2 (permalink)
kumarmohit's Avatar
Default Re: USB Pen Drive Problems
Try formatting it using Linux PC
kumarmohit is offline
Old 20-03-2008, 07:44 PM   #3 (permalink)
dOm1naTOr's Avatar
True crypt can be used to password encrypt and partition ur thumpdrive. It works for Corsair Voyager drives. Dun kow if it wud work with others.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 20-03-2008, 08:14 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
See if this thread can help you
Look @ the enable usb mass storage section.
Disable Access to USB Mass Storage Drive
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Problems with my pen drive dabster Reviews 2 21-03-2009 06:50 AM
USB pen drive problems the_player Hardware Q&A 2 02-01-2007 11:32 AM
Problems With Pen Drive In Windows Xp 2 drprabhatlkw Software Q&A 2 25-07-2006 07:30 AM
USB Drive Problems d Hardware Q&A 1 20-12-2005 02:03 PM
- by c4u
