Old 20-03-2008, 05:13 PM   #1 (permalink)
Default Mouse and UPS suggestions!
I need a new mouse, not cordless, PS/2 or USB will do! Max budget: 450
Also i need a new UPS, present 600VA doesnt provide back up for a m,ilisec and just goes of if there's a power cut... so i need an UPS with Power rating greater than 600VA... (I have a PC 350w SMPS, 17" CRT and DSL modem connected to UPS). Budget is 4000.
So throw in suggestions!!
Shwetanshu Srivastava
shwetanshu is offline
Old 20-03-2008, 07:29 PM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: Mouse and UPS suggestions!
U can either get Microsoft basic optical for 400 or Logitech Basic optical 1000dpi for 400/-. Both of them are worth.
And for 4k, u can even get powersafe 1KVA UPS. Or APC 650 is for 3.2k range. CRTs draws lot of power, so get the 1KVA one if u need gud backup. If the voltage is fluctuating nd will get much lower on evening time, then APC is better. If the line voltage is normal, then Powersafe is better option, nd more vfm.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 02-04-2008, 10:14 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
where can we get these type of mouse ?
ASUS K53SV SX520D + BF3
s18000rpm is online now
Need Suggestions! 144 Hardware Q&A 2 08-05-2006 09:37 AM
Wheel mouse optical and Basic optical mouse!!! raj_4588 Peripherals 5 05-08-2005 07:14 PM
Mouse Problem- Psyco Mouse!! khattam_ Peripherals 2 16-02-2005 06:54 AM
any suggestions????? mylifevp QnA (read only) 3 28-12-2004 08:15 AM
Any suggestions abt?? krish QnA (read only) 2 01-12-2004 01:25 AM
- by c4u
