Old 19-03-2008, 05:17 PM   #1 (permalink)
 Macboy
goobimama's Avatar
Default A small little motherboard query
I want to upgrade my machine. Was thinking of getting that Pentium dual-core 1.8Ghz CPU (E 2160) + Motherboard. Now the thing is I might want to soon upgrade that to a C2D (of maybe 2.66Ghz or so). Will the motherboards be compatible? Which board should I get?
Also, how silent are these C2D machines? I hate noise while watching movies and my Pentium 4 is acting like a whiny b**ch. The E4400 one I have at the office is not exactly silent (although not noisy as well). Maybe I could get some mid-end CPU cooler...
I'm like a bird... :)
goobimama is offline
Old 19-03-2008, 05:27 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: A small little motherboard query
not that silent.all C2D intel stock fans have same noise level.u will need to shed some cash on a better cooler- Hyper L3 for 1.2k would be enough.and a silent PSU too!
which motherboard are you buying?
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 19-03-2008, 06:19 PM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
wats ur budget?do u want onboard gfx or not?
XFX 630i - 3.5k with onboard gfx but no dual channel support
abit IP35-E - 5.5k no onboard gfx dual channel support
hellgate is offline
Old 19-03-2008, 06:21 PM   #4 (permalink)
You gave been GXified
gxsaurav's Avatar
Get Intel DG33FB with Intel Core 2 Duo E4500 atleast.
Later on, upgrade to Intel Core 2 Duo E 8200.
Where can we buy Cooler Master Hyper L3 for Rs 1,200?
about.me/gxsaurav
gxsaurav is offline
Old 19-03-2008, 06:25 PM   #5 (permalink)
Ethan_Hunt's Avatar
@goobi: Are you looking out for a motherboard which has onboard graphics or a motherboard without an onboard video? Eitherway both will have full compatibility with Core 2 Duo processors & many actually have Quad Core support too.If you want a motherboard with good onboard then go for ABit I-N73HD which has 7-series onboard video support along with HDMI port.If one without onboard video then go for an XFX 650i-Ultra board.
V for Vendetta
Ethan_Hunt is offline
Old 19-03-2008, 06:26 PM   #6 (permalink)
Alter Bridge=GOD
Lynx-India , Chandigarh
here's the link but the prices are not exactly what he sells at-they are lil less-
http://www.lynx-india.com/index.php?productID=175
and some items there are not updated,so dont use this website for a price check
Old 19-03-2008, 06:33 PM   #7 (permalink)
 Macboy
goobimama's Avatar
I already have a 7900GT so I don't need onboard support. PCIe 16x slot necessary. I want the cheapest of the cheap. Not looking for performance at all. Just good build quality. I'm pretty hell bent on getting that Pentium Dual core. It seems pretty 'cool' and gives decent performance (looking for 720p HD playback). I'll upgrade later on (now I have to spend on iPhone )
Old 19-03-2008, 07:04 PM   #8 (permalink)
Alter Bridge=GOD
^ Since u got a card , Abit IP35 E if u want to spend 5k , else DG31 -the one bought by gx
Old 19-03-2008, 07:13 PM   #9 (permalink)
j1n M@tt's Avatar
I think XFX 630i is better than DG31......it don't hav dual channel, but a single stick of 2GB 800MHz DDR2 will make up to it......
j1n M@tt || "a guy who gets off bed only b'coz of technology..."
j1n M@tt is offline
Old 19-03-2008, 07:15 PM   #10 (permalink)
Alter Bridge=GOD
its better for onboard gfx , but intel boards are more stable and got better build -thats what he wants
Old 19-03-2008, 07:18 PM   #11 (permalink)
j1n M@tt's Avatar
^^ya datz true......intel mobos hav better build quality
j1n M@tt is offline
Old 19-03-2008, 08:25 PM   #12 (permalink)
gxsaurav's Avatar
What u want is a HTPC, right?
Intel Core 2 Duo E4500. Trust me, this is better then Pentium Dual core for HTPC needs. Use Cooler Master Hyper L3 CPU cooler for a near silent Computer.
Intel DG33TL motherboard. Comes with onboard graphics, Fireport, & everything u will need. Here is a comparision of DG33TL & DG31PR, look yourself & see which one fits your requirment better.
Use your existing graphics card, it is good enough. Do u need a TV Tuner?
We can give u a solid config, but depends on what you want to do with it...plz specify
about.me/gxsaurav
gxsaurav is offline
Old 19-03-2008, 10:03 PM   #13 (permalink)
 Macboy
goobimama's Avatar
I just want the cheapest way to upgrade my machine into a silent, 720p playing machine. From my experience, the E2120 1.8Ghz dual core is capable of doing that and is pretty silent as well. I however don't want to get the 945 board since I might be upgrading the CPU to a C2D some time later. I don't need any performance, SLi, no 800Mhz RAM or anything like that. Just silent CPU + DDR2 + Mobo.
Old 19-03-2008, 10:19 PM   #14 (permalink)
j1n M@tt's Avatar
^^then XFX 630i or DG33 might be the right solution for u
j1n M@tt is offline
Old 19-03-2008, 10:27 PM   #15 (permalink)
gxsaurav's Avatar
If all you need is a HTP like setup then go straight for this & later on upgrade the CPU.
Intel Pentium Dual core E2180, runs at 2 GHz & good enough for all your HD needs even upto 1080p when combined with your GeForce 7 graphics card.
Cooler Master Hyper L3 CPU Cooler is a must for you.
Intel DG31PR motherboard, I am using it, it is like set it & forget it motherboard. Everything just works. If u need firewire port or 7.1 channel audio support then only go for DG33TL
Your GeForce 7900GT with Purevideo HD decoder.
Which monitor & speakers will you use?
For cabinet, I would recommend u to go to the market & choose yourself. This is PC market so customisation is the keyword here.
about.me/gxsaurav
gxsaurav is offline
Old 19-03-2008, 10:30 PM   #16 (permalink)
 Macboy
goobimama's Avatar
Cabinet, soundcard sab kuch hai. Using a 24" Dell + Logitech Z5500 + Auzentech Xplosion sound card + 7900GT + Hmm....
And I've come to a realisation that Purevideo HD is a Pure-ly useless thing. Especially for me.
I guess I'll inquire about the DG31PR then...
Old 19-03-2008, 10:47 PM   #17 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^dont get DG31PR cuz it doesn't support overclocking(I know you will say I wont\dont\needn't overclock but you might just want to get that extra bit of juice to play 1080p smoothly or something.
If I were you I would get Abit - IP35 E,which costs about 5k straight away.
ABit - I-N73HD,if you are a lil low on cash+it has very-very good onboard video but lacks dual channel support which isn't any big deal at all IMO.It is mATX and is superb for HTPC.Costs about 4k.
really wanna go low and wont spend a penny over 2-2.5k?Biostar GF7050-m7 which is about 2.4k.
they all suppost all c2ds(60nm),check out support for quad cores and 45nm before buying if you need it.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Old 19-03-2008, 10:50 PM   #18 (permalink)
gxsaurav's Avatar
Goobi, one advice. You got Cable TV or not? Make it a Home theater PC. If u don't have cable then buy Intel DG31PR motherboard with Core 2 duo E2180 CPU or E2160 CPU. Both are good enough for you.
Along with this, buy a Pinnacle Remote kit for Windows Vista. This is only a remote with IR receiver which works to control Windows Media center. Even if u don't use a TV Tuner card, there is nothing better then enjoying the content from 10 feet away & controlling using remote....this will remind u of Front Row
Originally Posted by The_Devil_Himself View Post
^^dont get DG31PR cuz it doesn't support overclocking(I know you will say I wont\dont\needn't overclock but you might just want to get that extra bit of juice to play 1080p smoothly or something..
Trust me, goobi isn't a overclocker
Core 2 Duo E2180 even at stock speed is good enough for his HD needs
about.me/gxsaurav
gxsaurav is offline
Old 19-03-2008, 10:53 PM   #19 (permalink)
^^yay,i trust everyone on this but still the potion should be kept open.
if you really wanna know,Intel mobo's absolutely suck.build quality my foot,........dont get me started on this.
Abit makes some of the best mobos around and that ABit - I-N73HD is like 100 times better than your intel whatever whatever.
Old 19-03-2008, 10:54 PM   #20 (permalink)
 Macboy
goobimama's Avatar
This I like. I'll get this when I get this.
And yeah, I have absolutely no intention of overclocking. If I need better speed, I can always get that C2D 8xxx series
Old 19-03-2008, 11:51 PM   #21 (permalink)
gxsaurav's Avatar
I told u na, goobi isn't a over clocker.
Finalize your config as..
Core 2 Duo E2180/2160, which ever is available. If E2180 is available then go for it.
Intel DG31PR motherboard.
PCTV Remote Kit for Windows Vista
2 GB DDR2 667 RAM
Hard disk as u like.
Your existing cabinet, graphics card, sound card, speakers, monitor.
Too bad iphone doesn't support bluetooth profiles like Sony Ericsson K750i supports, or you could have controlled your PC using the phone as a remote too
about.me/gxsaurav
gxsaurav is offline
Old 20-03-2008, 12:29 AM   #22 (permalink)
 Macboy
goobimama's Avatar
You think I would want my family to rub their grubby fingers on my iPhone? I might even have second thoughts on that PCTV remote. The speakers already have their remote. Too many of these things and I'll soon have to setup a remote shop.
Thanks for all the help and suggestions though. Virtual non-reps to all of you
Old 20-03-2008, 12:37 AM   #23 (permalink)
gxsaurav's Avatar
Goobi, you are in PC world right now. Anything you want is possible here....have a look a Logitech Harmony remote. One remote to control everything.
about.me/gxsaurav
gxsaurav is offline
Old 20-03-2008, 12:46 AM   #24 (permalink)
 Macboy
goobimama's Avatar
Yeah right. I will have to bend down and pick up many soaps (if you know what I mean) to afford that... I sure would love to own one of those though.
Old 20-03-2008, 10:31 AM   #25 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
intel DBOARDS are POS infront of gigabyte mobos are far as build quality & stability is concerned
gigabyte G31 mobos cost somewhere near 3k
secondly purevideo HD 2 or ATI UVD greatly enhance the playback of h.264 or vc-1 content .Most importantly even with a C2D 8200 without GPU hardware acceleration jitters are quite prominent..
a radeon HD 3450 is a very decent choice for getting UVD work..
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 20-03-2008, 10:41 AM   #26 (permalink)
gxsaurav's Avatar
Gigabyte motherboards might not be available, although GigaByte G31 motherboard will be a better choice due to more features.
He already has a GeForce 7900GT so why buy another graphics card just for HTPC purpose. Whether to use Purevideo or not is his choice.
about.me/gxsaurav
gxsaurav is offline
Old 20-03-2008, 12:19 PM   #27 (permalink)
 Macboy
goobimama's Avatar
Purevideo is useless boys. Totally useless. Maybe if I'm playing Blu ray discs maybe. But otherwise useless.
Old 20-03-2008, 05:11 PM   #28 (permalink)
gxsaurav's Avatar
In my system, I install K-Lite codec pack for FFDShow & that's it. It decodes everything & with K-lite codec pack comes cyberlink codec which I install to play DVDs.
That's all u need on Windows.
about.me/gxsaurav
gxsaurav is offline
Old 20-03-2008, 06:12 PM   #29 (permalink)
shadow hunter
lol....gx its no secret that a modern dual core proc with MPC HC + core avc handles 1080p quite well..
UVD & purevideo HD2 are designed to give "more accurate color per frame" & better post processing effects by lowering stress on cpu and their algorithms are pretty neat..
this link was given by "bottle" at other forum,try it and let us know more about it
How to get your (supporting) video card to decode h264
Old 02-01-2010, 04:02 PM   #30 (permalink)
Hey all.
I just wanted to know how to find out wether a motherboard has an integrated GPU or not.. and what is "Northbridge" and "Southbridge"
Thanks in advance
srk4all is offline
Widescreen help + 1 small query... gannu_rox Hardware Q&A 3 25-05-2007 05:52 PM
DFI INFINITY P965-S Motherboard - Query s18000rpm Hardware Q&A 2 10-04-2007 12:36 PM
Damn small linux made my pen drive small abhinavchadda Software Q&A 4 17-05-2006 01:25 AM
motherboard & processor query chitta CPU / Motherboards 17 16-10-2005 09:13 AM
Microtek Monitor Query and PHPBB Attachment Mod Query vwad Software Q&A 1 20-03-2005 09:32 AM
- by c4u
