Old 18-03-2008, 12:21 PM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Default DirectX 10 card!!!
We all know dat DX 10 is shipped with vista...
But...
If I have Dx10 Graphics Card then:
- can i use the DX10 (as in vista) in XP ?
- if not then DX10 card is not worth for XP..in terms of graphics processing
as in DX10 ?
Zangetsu is offline
Old 18-03-2008, 12:28 PM   #2 (permalink)
darklord's Avatar
Default Re: DirectX 10 card!!!
XP doesnt support DX10, so simply DX10 = Vista.
This doesnt mean, you shouldnt buy DX10 cards just because you will be using XP.Its not like the cards is going to perform horribly in DX9 and difference between DX9 and DX10 is not monstrous or anything when speaking strictly about the graphics part.
darklord is offline
Old 18-03-2008, 12:32 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
so, the card will not perform up 2 the mark as in vista...
so Vista is a must 4 DX10 gaming
Zangetsu is offline
Old 18-03-2008, 01:04 PM   #4 (permalink)
darklord's Avatar
In XP the card will run in DX9 mode and its ot bad at all seriously.
Yes for DX10, Vista is a must.
darklord is offline
Old 18-03-2008, 01:34 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
So what we have seen in crysis graphics (i.e gameplay trailer) is shown in
DX10....vista os.....
crysis is mainly 4 DX10.....if u wanna see full eyecandy
in DX9 its not that par
Zangetsu is offline
Old 18-03-2008, 02:49 PM   #6 (permalink)
"MKIN WAY 2 android"
Orionz's Avatar
Try the third party developed DX10 For XP....! [JUST HIT THE GOOGLE]
n
If you u really don't have a high end Rig......simply don't try to Gaming on Vista.... It will suck you down.....
Orionz is offline
Old 18-03-2008, 03:57 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
dat is a fake DX10 for XP.....
Zangetsu is offline
Old 18-03-2008, 05:44 PM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
now dont say that dood.
hav a look at my rigs's config (in my siggy).it runs Vista and all the games in full glory.any new procy (be it E2140) paired with 2GB of ram (minimum) and a gud enuf card like 8600GT will run Vista and all the games though not with all eye candy enabled.
hellgate is offline
S3 unveils low-cost DirectX 10 graphics card ... approx $60 shadow2get Technology News 16 28-02-2008 11:11 AM
DirectX 10.1 Requires No New GPU.But DirectX 10.1 Video Card Is Recommended sabret00the Technology News 8 19-08-2007 01:46 PM
problem with DirectX and Graphics Card slugger Graphic cards 2 02-05-2007 02:33 PM
Half Life 2 EP1 works on directX 7 card?!?!? cyborg47 Gamerz 3 28-03-2007 09:48 PM
has directx 10 based grafix card released bkpeerless Hardware Q&A 16 01-02-2007 02:10 AM
- by c4u
