Old 18-03-2008, 09:08 AM   #1 (permalink)
Revolution's Avatar
Question Need Motherboard For Intel Dual Core E2160
I am going to upgrade my P4.
I have already decided to buy
2 GB DDR2 RAM 800MHz
But,I can't find a good mobo that can overclock my E2160 easily.
It would be better if the mobo has 4 RAM slots.
Please suggest me a good mobo.
I want to spend as less as possible,max 3K.
Please suggest more than one because some brand like Palit,Biostar,Abit etc are hard to find in Kolkata.
Thanks in advance.....
Revolution is offline
Old 18-03-2008, 09:18 AM   #2 (permalink)
Default Re: Need Motherboard For Intel Dual Core E2160
xfx 630i - 3.5k no dual channel , 2 ram slots only . but has onboard gfx
abit ip35-e - 5.5k , best for budget but no onboard gfx.
sagargv is offline
Old 18-03-2008, 08:49 PM   #3 (permalink)
Fast 'N' Furious
topgear's Avatar
It's hard to find a good overclock a mobo in Rs. 3000. So......
Msi p35 neo fr2 Rs. 5000-6000 without onboard gfx.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Intel core duo t2450 @2 Ghz or intel dual core @ 1.73Ghz ??????????? arunks CPU / Motherboards 6 04-03-2008 11:54 PM
diff between Intel dual core,Core 2 , Duo?? NagpurDaMunda CPU / Motherboards 26 21-07-2007 06:37 AM
Best motherboard for AMD Dual Core ? esumitkumar Hardware Q&A 8 17-10-2006 01:31 PM
Intel dual core without HT or AMD64 dual core--which is best vps85 CPU / Motherboards 2 26-04-2005 01:02 AM
- by c4u
