18-03-2008, 01:17 AM
Please suggest a good latest Intel mainstream motherboard and proccy
Hi friends
After my 15 days effort of googlin around for a good future-proof motherboard, i came to a conclusion tht if i go for amd side, the new mobo's, namely msi k9a2cf anf gigabyte ga-ma78 are the only new comers. then after some decisions i went to finalize the msi k9a2cf but at the last moment i was told it wont support 125w cpus  so i just cancelled it and thought of gettin gigabyte GA-MA78 mobo but it was nowhere available in India......
So I have decided to go for intel side...
please suggest me the following:
1>Latest intel mobo supportin pcie2.0 and dts
2>mainstream intel proccy
I have 2k reserved for 2gb Ram........now i have left 10k rs. with me. Please suggest a mobo=proccy combination around 10k
Thanks
P.S. SLI and onboard video is not a requirement for me
Reason: Automerged Doublepost
18-03-2008, 02:36 PM
At Hell's Disq
Re: Please suggest a good latest Intel mainstream motherboard and proccy
u wont be able to buy a pcie2.0 mobo in that budget.the best bet in 10k is:
E4500 for 4.5k and abit IP35-E for 5.9k
18-03-2008, 03:39 PM
hmm......well abit is not available in my town
18-03-2008, 05:29 PM
At Hell's Disq
then either buy it online or look for MSI P35 Neo2 FR
18-03-2008, 08:41 PM
Fast 'N' Furious
+1 for msi p35 neo fr.
For procy go for e4500 or e6550 if you can spend rs. 2K more
18-03-2008, 11:58 PM
well......but wud it be better than amd 780g(gigabyte ga-ma78g) motherboard + amd 5200+ combination? I need good onboard audio for my x-530 speakers and 780g supports dts decoding(neo:6)
19-03-2008, 12:37 AM
At Hell's Disq
it wud surely be better than ur AMD config.
19-03-2008, 10:26 PM
@hellgate, u r using the p35 mobo, can you tell me howz the audio and overclocking power of ur mobo.........also is any of the E8xxx processor possible in my budget?
20-03-2008, 07:14 PM
Fast 'N' Furious
All mobos come with HD Audio These days which are decent for audio.
But if you are a audiophile then you should consider buying a good sound card.
ALso audio cards in range from Rs. 2500-3000 will outperform onboard sound solution anyday.
A e8400 proc is retailing around Rs.8000-8400
I don't know about any other e8xxx proc which could be found in range of Rs. 5000-6000
20-03-2008, 10:00 PM
At Hell's Disq
i got my IP35-E(5.9k) & E8400(8.6k) for 14.5k all incl.
i like this abit mobo,performance is gud maybe even better than my previous Asus P5B Dlx.
onboard audio is managed by Realtek ALC888 audio codec.it has 8 ch output in both digital(SPDIF) and analog formats.
overcloking performance is gr8 @ this price point.
21-03-2008, 01:27 AM
well e8400 is out of my budget for now
so the only thing i can go for is msi p35 neo2-fr and e4500
how is this config?
and does this mobo support ddr2 and ddr3 both??
21-03-2008, 09:44 AM
At Hell's Disq
only MSI P35 Neo Combo supports bo DDR2& DDR3 memory
21-03-2008, 10:29 AM
@hellgate:
which of the following would be better:
amd 5600+ + gigabyte ga-ma78g
or
e4500 + msi p35 neo2-fr combo??
21-03-2008, 02:21 PM
At Hell's Disq
the 2nd one by all means.
21-03-2008, 06:12 PM
ok so now i have finally made my mind to go on intel's side.
So please tell if Biostar TP35D2 - A7 would be a good option with e6500 (if it comes within 10k).........biostar is available in my town, i enquired today
Or which would be the best ip35 mobo apart from abit? asus would be ok?
21-03-2008, 07:16 PM
Fast 'N' Furious
^^ Hell yeah! The above config is good one.
By the what's the price you get for the mobo & proc ?
But that mobo doesn't supports latest penryn core procs like q9xxx or e8xxx
according to their website:
http://www.biostar.com.tw/app/en-us/...t.php?S_ID=286
But all intel p35 chipsets supports penryn core procs I think ? correct me if I am wrong.
21-03-2008, 10:30 PM
At Hell's Disq
afaik all P35 chipset based mobos support penryn procies.if the manufacturers site says that it doesnt support penryn then i dont think that it'll be a wise thing to buy it.
so its better if u buy MSI or Gigabyte (P35-DS3L).
another option is E8400 for 8.6k (all incl) and XFX 630i for 3.5k.total is bout 12k.
21-03-2008, 10:33 PM
i saw in another post that a guy managed to get gigabyte ga-ma78gm with 4800+ in bangalore.....
now i m thinking to order one from bangalore and couple a 5200+ with it.........when phenom prices go down, i can upgrade to phenom then!
ohhhhhh i m so confused
21-03-2008, 10:52 PM
#19 (permalink)
At Hell's Disq
dont even think bout buying X2 when u can afford a C2D.
22-03-2008, 07:11 PM
#20 (permalink)
Fast 'N' Furious
ya, c2d's are best bet for his budget
23-03-2008, 10:31 AM
#21 (permalink)
Where is Gigabyte DS3L available mate ? I have been searching like mad for that board
23-03-2008, 02:24 PM
#22 (permalink)
At Hell's Disq
^^^ a vendor in Kolkata said that he cud arrange for that mobo if i ordered for it.since i got the IP35-E in ready stock from another vendor i didnt order the Gigabyte mobo.
23-03-2008, 06:23 PM
#23 (permalink)
Ok thanks, how much is that board costing ?
23-03-2008, 07:27 PM
#24 (permalink)
how is the asus p35 board btw? cant get msi or giagabyte easily in my town
23-03-2008, 07:51 PM
#25 (permalink)
Overpriced
23-03-2008, 10:39 PM
#26 (permalink)
At Hell's Disq
^^^ wont be able to tell u the exact price but the vendor said it sud be bout 6-6.5k all incl.
23-03-2008, 11:18 PM
#27 (permalink)
Asus P5K costs 7.7k
23-03-2008, 11:25 PM
#28 (permalink)
man its so much overpriced  damn i need to get msi or abit
BTW is there anything special on this mobo as it costs so much
23-03-2008, 11:52 PM
#29 (permalink)
99.9% Idle
Biostar TP35D2-A7 supports penryn proc..but bios has to be upgraded for that...already available on their site... http://www.biostar.com.tw/app/en-us/...s.php?S_ID=286
and its a matter of single click with biostar bios utility.
24-03-2008, 01:29 AM
#30 (permalink)
^ ^ thanks :d
