Copy following code in notepad and save it as "Resetdma.vbs" with the quotes:
' Visual Basic Script program to reset the DMA status of all ATA drives
' Copyright © 2006 Hans-Georg Michna
' Version 2006-03-14
' Works in Windows XP, probably also in Windows 2000 and NT.
' Does no harm if Windows version is incompatible.
If MsgBox("This program will now reset the DMA status of all ATA drives with Windows drivers." _
& vbNewline & "Windows will redetect the status after the next reboot, therefore this procedure" _
& vbNewline & "should be harmless.", _
vbOkCancel, "Program start message") _
= vbOk Then
RegPath = "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\"
ValueName1 = "MasterIdDataChecksum"
ValueName2 = "SlaveIdDataChecksum"
ValueName3 = "ResetErrorCountersOnSuccess"
MessageText = "The following ATA channels have been reset:"
MessageTextLen0 = Len(MessageText)
SubsequentMisses = 0
Set WshShell = WScript.CreateObject("WScript.Shell")
For i = 0 to 999
RegSubPath = Right("000" & i, 4) & "\"
' Master
Err.Clear
On Error Resume Next
WshShell.RegRead RegPath & RegSubPath & ValueName1
e1 = Err.Number
Err.Clear
On Error Goto 0
If e1 = 0 Then
WshShell.RegDelete RegPath & RegSubPath & ValueName1
On Error Goto 0
MessageText = MessageText & vbNewLine & "Master"
End If
' Slave
Err.Clear
WshShell.RegRead RegPath & RegSubPath & ValueName2
e2 = Err.Number
On Error Goto 0
If e2 = 0 Then
WshShell.RegDelete RegPath & RegSubPath & ValueName2
On Error Goto 0
If e1 = 0 Then
MessageText = MessageText & " and "
Else
End If
MessageText = MessageText & "Slave"
End If
If e1 = 0 Or e2 = 0 Then
WshShell.RegWrite RegPath & RegSubPath & ValueName3, 1, "REG_DWORD"
On Error Goto 0
ChannelName = "unnamed channel " & Left(RegSubPath, 4)
ChannelName = WshShell.RegRead(RegPath & RegSubPath & "DriverDesc")
On Error Goto 0
MessageText = MessageText & " of " & ChannelName & ";"
Else
SubsequentMisses = SubsequentMisses + 1
If SubsequentMisses >= 32 Then Exit For ' Don't search unnecessarily long.
End If
Next ' i
If Len(MessageText) <= MessageTextLen0 Then
MessageText = "No resettable ATA channels with Windows drivers found. Nothing changed."
Else
MessageText = MessageText & vbNewline _
& "Please reboot now to reset and redetect the DMA status."
End If
MsgBox MessageText, vbOkOnly, "Program finished normally"
End If ' MsgBox(...) = vbOk
' End of Visual Basic Script program
After saving the file, just run it once. It will ask u to reboot ur computer. After rebooting, see if ur computer has become as fast as it was earlier. If that doesnt solve the problem, then, probably u hav some virus problem. Install some good antivirus like NOD32, update it and then scan ur pc.
