Old 16-03-2008, 08:14 AM   #1 (permalink)
Revolution's Avatar
Default Need Cabinet+PSU 4K
Please help me to chose cabinet and PSU !
I need a good cooling solution with good PSU.
Should I go for Zeb Bijli or Zeb PEACE or Coolermaster Elite 330.....
Should I go for Power Safe or VIP or Zeb Platinum PSU.....
Or suggest me something else.
My budget is 4K.
It would be better if anyone tell me the price and
name+address of Hardware Vendor in Kolkata.
Thanks in advance.....
Revolution is offline
Old 16-03-2008, 09:11 AM   #2 (permalink)
Default Re: Need Cabinet+PSU 4K
I have a zebronics Peace & platinum 550 watt PSU.
Peace cabby though many would suggest but its not so good in airflow management, the big fan it has blows load of air & DUST directly on to the cpu fan & I have to clean it every months by opening the entire cabinet.
That big fan (air intake) should be in front.
If you are really looking for a good cabinet then I suggest invest more (cabinet will last more than your comp)
Antec & coolermaster have some good choices Rs 4000 to 7000/-
ranjan2001 is offline
Old 16-03-2008, 09:29 AM   #3 (permalink)
dOm1naTOr's Avatar
is the 4k budget for cabby+PSU?
then u have no other choice than peace/antibiotic
both are for 2k w/o PSU. U can get Zeb 500W platinum for 1.8k. Ive once used my platinum 500w with my friend's 7800GTX 512[needs power close to 8800GT].
Now im using it with my 7600GT oc, and it handles it well.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Cabinet Mod . . . . .LED int86 Hardware Q&A 35 04-09-2006 03:24 PM
need help regarding Cabinet nd4spd Hardware Q&A 11 02-04-2006 07:58 PM
which Cabinet to buy... jay4u Hardware Q&A 59 21-03-2006 02:43 PM
Cabinet help please!! jetboy Hardware Q&A 16 20-11-2005 09:06 AM
- by c4u
