Old 15-03-2008, 10:40 PM   #1 (permalink)
Just Do It
Charley's Avatar
Question Intel Core 2 Duo 2.0 ghz, 2 GB Ram, 160 GB hard disk - Purchased Today
I get this error while installing Win XP
A problem has encountered and windows has been shut down to prevent damage to your computer.
1. If this is the 1st time you've seen this stop error screen, restart your computer. If this screen appears again follow these steps.
2. Check to be sure you have adequate disk space.
3. If a driver is identified in the stop message disable the driver or check with the manufacturer for driver ipdates.
4. Try changing video adapter.
5. Check with your hardware vendor for any BIOS updates.
6. Disable BIOS memory options such as caching or shadowing.
7. If you need to use safe mode or remove or disable components, restart your computer, press f8 to select advanced options & select safe mode.
Technical Information
STOP : 0x0000007E[0XC000005, 0XF748E0BF, 0XF78DA208, 0XF78D9F08]
pci.sys - Address F748E0BF base at F7487000, Date Stamp 3b7d855C.
I bought the new system today[not second hand],is an assembled one. My friend tried everyhting except 6 & 4. How to do 6 ? Also someone help me with this problem.
Charley is offline
Old 15-03-2008, 11:09 PM   #2 (permalink)
Ethan_Hunt's Avatar
Default Re: Intel Core 2 Duo 2.0 ghz, 2 GB Ram, 160 GB hard disk - Purchased Today
Ah the evergreen BSOD issue.Check your RAM or the HDD.Either one of them must be the culprit here.Try using single RAM stick & check with each one.
V for Vendetta
Ethan_Hunt is offline
Old 15-03-2008, 11:12 PM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
wat mobo do u hav and is ur procy a E4400.also wat psu r u using?
hellgate is offline
Old 15-03-2008, 11:17 PM   #4 (permalink)
ajaybc's Avatar
Talking Re: Intel Core 2 Duo 2.0 ghz, 2 GB Ram, 160 GB hard disk - Purchased Today
I had the same problem at first.
I set the hard disc as the master using the jumper and tried installing XP from another CD.And it worked!
Available for freelance web design and web development jobs.
You can view my portfolio here.
Ajay Balachandran
Please contact via PM
ajaybc is offline
Old 15-03-2008, 11:54 PM   #5 (permalink)
mayanksharma's Avatar
Check the RAM modules. Try plugging in different DIMM slots and set BIOS to optimized. And as its assembled, make sure everything is inserted and installed properly on mainboard. Basic thing, but it helps often!
mayanksharma is offline
Old 16-03-2008, 02:21 PM   #6 (permalink)
Just Do It
Charley's Avatar
Please tell me how to
- Set hard disc as master using jumper ?
- Instal XP from another CD, I already have the XP CD
Charley is offline
Old 16-03-2008, 03:10 PM   #7 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
those jumpers were with pata hdds afaik.
its not a psu issue-must be a ram\video card problem.
give ur config details
Apple Macbook Pro 17 :cool:
nish_higher is offline
Intel core duo t2450 @2 Ghz or intel dual core @ 1.73Ghz ??????????? arunks CPU / Motherboards 6 04-03-2008 11:54 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
Intel ships first quad-core Core 2 Extreme QX6700 sabret00the Technology News 4 15-10-2006 12:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by c4u
