Old 15-03-2008, 09:29 PM   #1 (permalink)
ayush_chh's Avatar
Default cannot format flash drive
hi
i have a Sony Micro vault 16GB. The problem is it is detected by the OS but it shows raw filesystem. i cannot format it from anywhere(diskmanagement, command prompt, not even from sony format software, it says no device found).
pls help.......
PS:- i have Fedora 8 and Win Xp installed. i am new to Linux so if there is any way pls tell.
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 15-03-2008, 09:48 PM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: cannot format flash drive
Use XP to format it
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 15-03-2008, 10:12 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
yaa..try in windows XP. If win Xp also fails to detect, than I think it is hardware issue.
ravi_9793 is offline
Old 16-03-2008, 04:12 PM   #4 (permalink)
ayush_chh's Avatar
i said i have already tried every method in win XP but i don't knowabt Fedora
How to convert ordinary flash drive into U3 smart drive? thetopcyborg QnA (read only) 13 02-11-2008 11:59 PM
dont install OS on flash drive/damn small linux corrupted flash drive vish786 Open Source 2 28-07-2007 05:29 AM
Need some suggestions about buying Pen Drive(flash drive) ~It_is_Andrew~ Hardware Q&A 16 14-09-2006 10:23 PM
flash memory size changed after format!!! romeo_8693 Hardware Q&A 16 22-01-2006 06:29 PM
Diffrence between an usb pen drive & a flash pen drive? harpoon Peripherals 3 18-01-2006 11:25 PM
- by c4u
