Old 15-03-2008, 03:57 PM   #1 (permalink)
I M A *STAR*
saqib_khan's Avatar
Smile Whatever display i see, is yellowish, pls help.
Hi,
Whatever image i see is yellowish, whether it is my desktop, during bootup process,etc. In short y r the colours not appearing like they should.
I also connected another CPU on the same monitor but the same problem. Now i think the problem is in my monitor only. And my Computer Engineer also said that the monitor needs repairing.
Is there anything which i can do? Plz help.
Blogging at:
Technostarry
saqib_khan is offline
Old 15-03-2008, 05:44 PM   #2 (permalink)
Web developer
narangz's Avatar
Default Re: Whatever display i see, is yellowish, pls help.
I guess the color temperature of your monitor needs to be changed. Its set to 6500K most probably. You need to set it at 9300K.
To change the color temperature use the controls on front of your monitor.
narangz is offline
Old 15-03-2008, 07:45 PM   #3 (permalink)
I M A *STAR*
saqib_khan's Avatar
Sorry, colour became worse. Didn't helped.
Blogging at:
Technostarry
Old 15-03-2008, 09:35 PM   #4 (permalink)
that is problem with u r monitor's color ic change the color ic if possible or buy a new one
prakashr85 is offline
Old 15-03-2008, 10:08 PM   #5 (permalink)
I M A *STAR*
saqib_khan's Avatar
i too think that it need's chip level repairing.
Blogging at:
Technostarry
Old 15-03-2008, 10:15 PM   #6 (permalink)
Web developer
narangz's Avatar
Yeah, get it checked with some service professional.
narangz is offline
No display - Help Please! caleb Hardware Q&A 9 12-08-2007 07:41 PM
no display raysoni_r Hardware Q&A 4 26-01-2007 09:27 AM
need a 19'' display rama007 QnA (read only) 15 01-10-2005 04:21 AM
display vignesh QnA (read only) 6 19-02-2005 06:38 PM
No Display... QnA (read only) 5 07-08-2004 08:14 AM
- by c4u
