1. I want to clean my optical drive. Could you give me guidance as to where I can find links to workshop which shows me how to clean my optical drive in detail.
2. I have Windows XP PRO. I have 3 user accounts on my desktop. Myself my wife and my daughter. I had some video clips on my hard drive. I played only one video clip on windows media player. I had no issues. My nephew came the other day and downloaded some songs for my daughter on her user account. Then whenever I switched user accounts from hers to mine and shut down the system it would warn me there is another user using the programme.
Then one day I installed winamp. I was able to use winamp too. Then I downloaded songs from an old cd of mine on the hdd in my user account.but till date I have not been able to play any songs on either wmp, winamp, or vlc player. I did not understand the theory behind this. And whenever I put off the computer I got the same message.Programme is being used by another user. I uninstalled winamp but still I am unable to play any music. I tried wmp. the moment I double click the music file in wmp the video clipping starts. Please help.
3. I have a programme which I want to uninstall. But its not listed in the add remove programme. How do I uninstall the programme.
4. I have to send many photographs to send over the net.how do i send so many photographs without destroying the colour and the size.it takes 10 to 20 minutes to attach 1 photograph.so you can imagine how time consuming it is.can you recomend free software which has all functions like cropping and compressing without changing colour of the photographs.Please help.
5. Whenever I format my hard drive, I have to install my XP PRO OS and Drives from two different CD’s .Is it possible to install the OS and Drivers software from 1 CD instead of 2 CD’s. Also I have another problem. I also have pinnacle TV tuner card installed. But when I installed the software which I came along with the card i did not get the driver. So as a result I could not watch my tv shows on my computer. I had to ask my technician who comes to repair my computer. He borrowed the driver CD from another customer of his and installed it for me.That is on another CD. I went to the Pinnacle website, but in the drivers section no drivers which are compatible were found compatible So I have to install software from 3 CD’s. so instead can I install all three softwares from one cd which will be done automatically. Could anyone help me
Ronald Quadros.
