Old 15-03-2008, 12:51 PM   #1 (permalink)
joy.das.jd
Posts: n/a
Smile Suggest a Laptop under 40K
Well my friend wants to buy a laptop. His budget is around 40K-45K. He will be using it for general purpose and wants a good screen for it. He will not do any gaming so graphics is not very important. Moreover he will use it on windows Xp and linux too. So pls suggest a good laptop. The ones selected are
http://www-604.ibm.com/webapp/wcs/st...86018425154304
http://www-604.ibm.com/webapp/wcs/st...86018425052502
http://www.dell.com/content/products...b_1520_anav2~~
But other models are welcome too.
Old 15-03-2008, 01:01 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Suggest a Laptop under 40K
Dell 1525.
Pathik is offline
Old 16-03-2008, 07:17 AM   #3 (permalink)
Arun the Gr8's Avatar
Lightbulb Re: Suggest a Laptop under 40K
Originally Posted by Pathik View Post
Dell 1525.
Yeah man ... go for the Dell... they have superb laptops and at a resonable price too .
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Suggest a LAPTOP under 45K??? jal_desai Laptops and Netbooks 11 05-12-2007 01:58 PM
Suggest a Laptop to buy? 6ranjitha6 QnA (read only) 11 20-10-2007 11:43 PM
Suggest laptop for Rs. 40k to 50k ilugd Laptops and Netbooks 1 18-09-2007 11:39 AM
Suggest me on which laptop to Buy... saipradeepg Laptops and Netbooks 3 19-02-2007 07:17 PM
Please Suggest a Laptop for 80K freshseasons QnA (read only) 8 20-11-2004 12:03 AM
- by c4u
