Old 15-03-2008, 09:55 AM   #1 (permalink)
joy.das.jd
Posts: n/a
Default How to change the Vcore of the CPU?
With reference to the thread of CPU running hot
http://www.thinkdigit.com/forum/showthread.php?t=82485
Some of the members suggested to lower my Vcore of the cpu. I have no idea how to do that. So can anyone help me out there solving that problem? I am running P4 (intel P4 515) on the Asus PTGD1-LA.The bios version i am using is V3.28.However there is no such thing so as to regulate the cpu voltage from within the bios. The complete report of EVEREST is located at
http://www.mediafire.com/?zxyzj0ywkbw
or
http://rapidshare.com/files/99635512/Report.txt.html
Can anyone help me out ??? Pls this is urgent as i do not want to fry up my processor.
Old 15-03-2008, 10:48 AM   #2 (permalink)
darklord's Avatar
Default Re: How to change the Vcore of the CPU?
If your BIOS doesnt allow vcore control, then i am afraid you cant do much about it.
Also regarding the CPU running hot, have you looked into the ventilation of your case ? If its not right, recitfying it will improve the cooling efficiency for sure.
darklord is offline
Old 15-03-2008, 11:23 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
remove proccy HSF,clean all the dust,remove the thermal paste from both the procy and hsf and then reapply thermal paste and install the hsf.
u sud see some drop in temps.
hellgate is offline
Need to change AVI to WMV! gabriel_409 Reviews 10 13-12-2007 10:31 PM
change in Ghz Ishan CPU / Motherboards 3 30-07-2006 07:39 PM
Change your ip in less than 1 min.!!! eagle_y2j Tutorials 14 05-07-2006 07:12 PM
monitor colour change on direction change mohanty1942 QnA (read only) 7 05-02-2006 05:05 PM
Change IP adorablesrini QnA (read only) 3 14-01-2005 08:33 PM
- by c4u
