Old 14-03-2008, 06:30 PM   #1 (permalink)
Default problem in booting - dg31pr + e8200
processor - c2d e8200 2.67ghz 1333fsb
mobo - dg31pr (g31 chipset) 1333fsb
ddr2 2gb 800 transcend
the board supports 1333fsb and is compatible with the processor as seen from intel's website.
there is no POST, no beeps, blank display.
what is the problem? do i need to flash the board? or what?
swapnil82 is offline
Old 14-03-2008, 06:44 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: problem in booting - dg31pr + e8200
wat psu r u using?
hellgate is offline
Old 14-03-2008, 07:33 PM   #3 (permalink)
Originally Posted by hellgate View Post
wat psu r u using?
default psu that comes with iball atx cabinet.
12v - 17 amperes
5v - 32 amperes
3.3v ~ 25 amperes
~ 400+ watts max
but i haven't installed any power hungry devices.
Old 14-03-2008, 07:42 PM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ get a better psu.atleast a zebby platinum 400/500w.sud solve ur prob.
hellgate is offline
Old 14-03-2008, 08:51 PM   #5 (permalink)
as i said it contains only mobo+cpu+ram.
any psu can deliver this much power. isn't it so?
Old 15-03-2008, 12:14 AM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
most of the time these local psus do manage to pwr a mobo + cpu + ram combo but sometimes their 12v rail is too weak (faulty) to pwr even such things.
hellgate is offline
Old 15-03-2008, 10:56 AM   #7 (permalink)
darklord's Avatar
Have you updated to latest BIOS to support 45nm CPUs ?
Also get a better PSU and try booting with a single memory stick.
darklord is offline
Old 15-03-2008, 02:48 PM   #8 (permalink)
I guess I have to flash the board, but I don't have another processor to do that
I have another problem -
I heard Intel motherboards don't support the LCD monitors with native resolution of 1440x900 (widescreen). (Or at least it is distorted). Is that true? In that case I will have to replace my monitor.
Old 15-03-2008, 03:07 PM   #9 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ u can take the mobo to the vendor from whom u got it.he'll flash it 4 u.but first check wats the present b ios version of mobo and whether any update is available.
for ur 2nd prob:
wat u've heard is not true.theres no issue in running a 1440x900 res lcd with Intel onboards gfx.ppl how hav reported such things were having gfx driver issues.
hellgate is offline
Old 15-03-2008, 03:43 PM   #10 (permalink)
Ranjya's Avatar
your sig has a abit ip35-e mobo.
How good is this mobo?
You have oc'd your proccy to 4.Ghz>>.....really
Which ram are you using ?
How stable is the mobo ??
Which powersupply??
Ranjya is offline
Old 15-03-2008, 06:46 PM   #11 (permalink)
At Hell's Disq
hellgate's Avatar
abit IP35-E is a good mobo with gr8 oc potentials.
yup i've oc'd my E8400 to 4.05GHz and its no big deal.E8400s easily oc to 4GHz and above.
ram is 3 sticks of Transcend 1GB DDR2 667 running at 900MHz.
mobo is perfectly stable.
PSU is Coolermaster 650W.
hellgate is offline
Old 17-03-2008, 01:05 PM   #12 (permalink)
spyingshadow's Avatar
really???
what exactly is d ram's model....
So, is 667mhz better than 800mhz in dat case???? what is d memory timing????
also, vot's d cost of d psu n mobo???
laslty, r u using any cooling set up, apart from stock fans n all
Cant catch vot ya cant see 8-)
spyingshadow is offline
Old 17-03-2008, 01:59 PM   #13 (permalink)
At Hell's Disq
hellgate's Avatar
ram is the normal Transcend Jet ram.
its better to buy 800MHz ram if u plan to oc ur E8400.u wont be limited due to ram.
mobo cost me 5.9k incl of all taxes and psu costs 4.7k (6months back).
i've got 5 cabinet fans and i'm setting up a cooling setup shall post pics 2night.
hellgate is offline
Old 17-03-2008, 07:33 PM   #14 (permalink)
that's great!!!!!
but, i dont hv d money 4 an e8400, i'll only b gettin an E6550 with dual channel transcend 800mhz 2gigs
Old 08-04-2008, 10:18 PM   #15 (permalink)
hi,
iŽve the same problem with this motherboard and a c2d e8400. in the intelŽs website say that is possible install this procesor in dg31pr.
in a few minutes i will try to update the bios to 0047 version (lastest). iŽll install a q6600 (quad 2 core 2.4 65nm) temporarily to do that and soon iŽll write the results.
iŽm really disappointed with this motherboard
idox is offline
Old 09-04-2008, 08:26 AM   #16 (permalink)
Someone suggested me to buy DG31PR for E4500. Now I will rethink
spp_itim is offline
Old 09-04-2008, 11:09 AM   #17 (permalink)
At Hell's Disq
hellgate's Avatar
dont buy Intel original mobos.better buy some good chipset mobos
hellgate is offline
Old 14-04-2008, 12:40 AM   #18 (permalink)
Originally Posted by idox View Post
hi,
hey idox, please tell your results of bios upgrade. is it successful and running e8400?
Old 21-04-2008, 11:30 AM   #19 (permalink)
yes men, is runing very well i recomend u install another processor to update the mb bios to the lastest version 0047(go to the intels websiteŽ). with this version the mb run all the 45nm processors. e8200, e8400
check the pic.
idox is offline
How is Intel DG31PR ???? spitfire Hardware Q&A 5 14-03-2008 08:52 PM
booting problem on my pc jatt Software Q&A 6 27-02-2007 03:09 PM
booting problem gau_pppu Hardware Q&A 2 23-11-2006 01:52 PM
booting problem amey kerkar Software Q&A 5 30-07-2006 03:36 PM
- by c4u
