Old 14-03-2008, 03:19 PM   #1 (permalink)
Question RAM in branded PC's
I have a branded LG PC with 256 RAM, and 40GB HD plz tell me if i can get my ram upgraded to 2 GB??????
tarundham is offline
Old 14-03-2008, 03:24 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: RAM in branded PC's
Please dont double post. Moved here..
kalpik is online now
Old 14-03-2008, 03:24 PM   #3 (permalink)
please post in appropriate section.
Yes its likely possible
Faun is online now
Old 14-03-2008, 03:24 PM   #4 (permalink)
BlackBerry Guru ! :)
BBThumbHealer's Avatar
yes , u can get the upgrade done but first let us know ur PC's motherboard model !
Username Changed - BlackBerry7100g To BBThumbHealer ! :D
BBThumbHealer is offline
Old 14-03-2008, 03:29 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
Hey dude y r u double posting............
Zangetsu is offline
Old 14-03-2008, 03:48 PM   #6 (permalink)
Dreamweaver
Gigacore's Avatar
SD or DDR ?
if it is SD, better buy a new mobo, ram and cpu
Gigacore is offline
Old 14-03-2008, 03:52 PM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
Read the motherboard manual to find:
1) Type of RAM supported
2) Maximum RAM memory supported.
if your motherboard support, than yes you can upgrade.
ravi_9793 is offline
Old 18-03-2008, 06:36 PM   #8 (permalink)
Thumbs down Re: RAM in branded PC's
Thanks everybody for helping me
but i don't know the model of my mobo
but ill try to find it from LG
LG ROXXXX!!!!!!:confuse d:
Old 18-03-2008, 08:16 PM   #9 (permalink)
TechTin.com
ravi_9793's Avatar
You dont need to know model number of motherboard. You can find it from motherboard manual....or simple take your RAM chip, and shop to shopkeeper.
RAM in branded PC's tarundham Hardware Q&A 2 14-03-2008 03:33 PM
A PC's turn on. SleepingBeagle Hardware Q&A 3 12-01-2008 01:26 PM
Usb 2 usb connection between 2 pc's vish786 Peripherals 6 24-08-2007 12:07 AM
Which type of PC's do u have????? q3_abhi Gamerz 85 05-01-2006 12:23 AM
- by c4u
