Page 16 of 27 FirstFirst ... 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 ... LastLast
Results 451 to 480 of 787
  1. #451
    Apprentice haider_up32's Avatar
    Jan 2008
    Lucknow
    Default Re: Hardware that you should NOT buy
    Kingston value ram ddr2 800mhz 2 pieces (short model). i bought it accidently from computer empire after paying at 1st floor and receiving it on 2nd. it was exported the same month by computer empire . it doest meet jedec ddr2 specs. it runs at 6-6-6-18 and doesnt overlock much.I sold 1 of the modules.
    The new digIT forum with all those adds sucks!!! Learn some adsense.
  2. #452
    Bond, Desi Bond! desiibond's Avatar
    Oct 2007
    Bangalore
    as the name says, it's VALUE ram. you can't expect that to take overclocking!!!!
    Samsung Galaxy S3 running cm10.1 nightly, Samsung Omnia W, Thinkpad T430 (Core i5, 8GB RAM, 160GB SSD, 14" 1600x900,9cell battery). Desktop: AMD Athlon X2 7750 BE, 4GB DDR2, 1TB HDD, 2600XT, 19" LCD
  3. #453
    CpyderGraphix cpyder's Avatar
    Mar 2005
    @desibond, bumped on your first post in this thread.. terrific list. Thanks a ton. it would come in handy. I wonder if you updated it since then?
    Though there is one generic 'No' from you about AA powered DigiCams. Well, I disagree very strongly on that. Infact, i always suggest people to go for digicams powered with AA batteries if there is a choice.. ofcourse i have my reasons..
    -you can buy a new set of batteries from a roadside shop, even if you are trekking somewhere in himalyas if your 'Li ion' battery drains out. - - a huge huge positive.
    - Li ion batteries are pretty much properitery, so you have to get back to the manufacturer for replacement and they are costly. More importantly its difficult to find them other than big cities. The camera models as well as battery designs change very much like other IT stuff, so if your cam is getting old, chances are you wont find your replacement battery easily.
    -AA size rechargeables are available. A set of four 2700 mAH capacity would cost about 1.5 to 2k. Do the math.. 2700 x 4 = 10800 mAH. While those Li Ion batteries are just about 1000 mAH to 1200 mAH costing about same. See how costlier they get?
    Oh,, and lastly, i can use them in my torch as well..
    Regards..
    See you at anditworkedforme.com
  4. #454
    Oct 2007
    Bangalore
    @cpyder, what you said is true. I have seen couple of high capacity AA sized batteries and they are as powerful as a single Li-Ion battery.
    Removed the entry from the list and thanks a ton for bringing this into light
  5. #455
    Jan 2008
    Lucknow
    Quote Originally Posted by desiibond View Post
    1. Transcend value ram ocs well
    2.The old kingston model is CL5 and meets the jedec specs of DDR2
  6. #456
    Right Off the Assembly Line rakz's Avatar
    Dec 2008
    Sony DVD RW....It sucks...Works only for a year and then stops writing only reads DVD's.
  7. #457
    GOD vaibhav_jain's Avatar
    Oct 2008
    Delhi
    recently i purchase kingston RAM from computer empire for my friend. When i install it then there is no display because of faulty RAM. And when i get back to computer empire for replacement then the employee there says that he can`t replace because it may be burnt. He told me to go kingston for replacement. In short i want to say that COMPUTER EMPIRE is VERY BAD shop for purchasing computer hardware.
    Vaibhav Jain
  8. #458
    AMD - Aaja Meri Darling
    Sep 2009
    Aapnu Amdavad, Gujjuland.
    Dynet ram - even though its better than other unheard of names, it failed on mine. Didn't know what the problem was before and i used to get like BSOD's quite often last 2 months. The module completely died last month. Replaced with Transcend premium memory (DDR 512MB x 2) and its all okay now.
    Personally I am a bit ... off about Seagate. I had a better impression before.
    I bought my Seagate IDE 250GB harddrive 4 years ago and it still works flawlessly with zero errors. It was a proper boxed piece in a red box, sealed properly.
    However my second seagate harddrive which was barely bought one year ago (a 160GB IDE Disk) failed very recently. This drive I was hesitant to buy cause all it had was a loose flimsy plastic cover with a sticker of seagate on it as packaging. (even a cheaper nokia 1100 comes in a better solid box ) The seal was just a cellotape.
    I got the error during boot up that the smart status was bad and the disk was prone to failure, and wouldnt proceed. So detached the drive, put it in an external USB converter case and used it as a removable disk and took whatever data that was necessary ( I usually have backups). The drive works still but the read write times are way too much even though it wasnt in PIO mode (now it is ..) Even the IDE cable is new.
    I think ill go with WD drives soon enough, depends really
  9. #459
    Oct 2007
    Bangalore
    guys, I have updated the list today. Let me know if I missed anything.
    Remember, it should be a product having mass failure rate and not one with one or two scattered incidents.
  10. #460
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    Add Asus DVD Writer and Starlite Rams ( Know many cases )
    & Don't Forget to add XBOX 360
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  11. #461
    Apr 2005
    Kollam, Kerala
    Quote Originally Posted by topgear View Post
    Though I have bot personally used it, Asus DVD writers are preferred by experts since they are known to be re-branded Pioneer drives.
    V.Prem Kumar
  12. #462
    Sep 2009
    @ Janitha,
    Yeah I've seen that too, however consumer support is one of the most important factors while buying it.. I read somewhere in this forum only about a bad experience with ASUS dvd rw, and to add to that the sales and support staff were noobs making it very frustuating.
    So even if a device is like supposedly used by the experts, unless there is proper support staff when there is a problem, I'd stay away from that product. Buying a fast moving/selling and known product is the best bet in case your product goes bad and needs a replacement.
  13. #463
    Apr 2005
    Kollam, Kerala
    Quote Originally Posted by Xeno View Post
    @ Janitha,
    Absolutely true. Pioneers are preferred for dual layer writing, scanning etc. But even two days back I bought a Samsung SH 223B since there is a service centre even in this small city, though Asus too was available. My earlier one too was Samsung.(SH 203B)
    V.Prem Kumar
  14. #464
    Oct 2007
    Bangalore
    xbox 360 is already added (to stay away from non-jasper)
    adding ASUS dvd burners.
  15. #465
    Jul 2006
    Geek's Heaven
    @ janitha - I've replaced one of my asus DVD writer 2 times and all of them were giving same prob.
    BTW, they replaced my new DVD drive with some old drive ( same model ) and next time they replaced with with a different model ( it was also old ). Though I've complained about it they refused to give me a new DVD drive.
    The 2nd replacement drive worked fine for amonth and then it stopped working on july.
    As I've received very bad customer support for them and being frustrated I'm unwilling
    to send it back again for replacement. I would only send it back for replacement if they will agree to give me a new replacement drive but nobody cannot guarantee over that. So I belive asus has only repair or replacement with old drive policy for DVD writers which is very bad. So I said to stay away from asus DVD drives as Xeno pointed good product not only depends on it's quality but it's greaty depend on good after sales service.
    @ desibond - My bad, haven't noticed about xbox 360.
    Thanks for adding asus DVD writers. This will save many consumers
    Who Dares Wins
    Avenging Angel !
  16. #466
    Sep 2009
    Yet another example of a good product being ruined by a bad service.
    I've had the experience when I owned a motorola V3i, they took 2 months just to get the display replaced, the V3i was a popular enough set, forget about the service for sets a bit less known.
    Learnt a good lesson from this. Warranty doesnt mean much if your product will be going back to the service center and lie there for a month or more. What about the time you didnt get to use the gadget even ? There's no compensation for that.
  17. #467
    Jan 2008
    Lucknow
  18. #468
    Right Off the Assembly Line Ypschita's Avatar
    Jun 2006
    India
    Hi
    Am looking for a basic machine to do heavy duty Word/ Excel/ PDF related stuff. And loads of space.
    Which motherboard and processor should I go for?
    I want atleast 2 GB DDR2 RAM, 320 X 2 SATA HDD, DVD RW Drive, Standard USB ports and Audio/ Video, Wireless Keyboard and Mouse.
    What should I look for and how much will it cost approximately in Mumbai?
    Regards!
    It is in changing that we find purpose!
  19. #469
    Oct 2007
    Bangalore
    ^^not this thread. wront post.
  20. #470
    Sep 2009
    Cool Re: Hardware that you should NOT buy
    Sony PSP 1001
    the 14,000 rs value pack
    waste of money buttons get jammed and dont work espesially the " X " button
    yeah if anybody knows how to fix it plz mail me clayheadstudios@gmail.com
    and
    sony cybershot DSC-s730
    bad feature and low mp rate grainny pics
    and
    tata indicom internet connection ( broadband )
    worst speed and worst service
    and
    telenet tndsl 2120
    worst modem in history
    and
    Sony Ps2 "fat version"
    xtreamly long time to load and read a dvd and memory card
    and
    my computer of corse
    he he he but its true
  21. #471
    I Can Therefore I Am
    Oct 2009
    Chennai
    plz don't buy dynet rams and asus motherboard
    dynet rams are getting trouble thrice in a year and asus does not support ethernet booting
  22. #472
    Oct 2007
    Bangalore
    now, how many use ethernet booting? And I don't think it's a valid reason to keep ASUS in the list!!!
  23. #473
    I need PC help
    Oct 2009
    Bangalore
    Quote Originally Posted by rakz View Post
    I agree with you. I had the similar experience. Sony sucks
  24. #474
    Project Halcyon V2.1 tkin's Avatar
    Aug 2008
    Hyderabad, India
    Quote Originally Posted by venkat0052 View Post
    You sure? My P5Q has a Lan boot option in bios.
    2600k/Z68VPro/Vengeance/U12PSE2/TX750v2/1TB.Black/DRWB5ST/HAF912+A
    M35/PortaPro/E30/Optimus.L9/Siberia/5800XM/FZ150/SH14/FiiO.E6
    Dell.15R/Ci3.3110m/7670m/ALVS4621/Funbook/Ferox
  25. #475
    Jul 2006
    Geek's Heaven
    May be he pointed to low end mobos.
    Who Dares Wins
    Avenging Angel !
  26. #476
    Super Moderator asingh's Avatar
    May 2008
    New Delhi
    ^^ What is ethernet booting..?
  27. #477
    Jul 2006
    Geek's Heaven
    It's same as LAN booting. You can istall OS on comp without a ODD or usb drive. Just Place the bootable media in the server and set the other comp to boot from LAN/NIC.
    BTW, the OS ( installation media ) must support LAN/NIC booting. Most linux distros supports LAN booting by default though
    these links will help you a lot
    http://versalogic.com/kb/kb.asp?kbid=1371
    http://msdn.microsoft.com/en-us/library/ms901800.aspx
    http://www.ethernut.de/en/eboot/index.html
    Who Dares Wins
    Avenging Angel !
  28. #478
    Jul 2008
    SEAGATE sux... my 6 months old 500 GB died yesterday.... all my data is gone as it will be replaced (as said by the dealer)
    *CRY*
    [Intel C2D E7200] [MSI MS-7507] Palit 9600 GT 512 MB] [Transcend 2x1GB 667 MHz] [Windows 7 RC1] [Samsung 943 NWX] [Samsung SH-223] [Brother HL-2140] [Logitech Dual Action Controller]
  29. #479
    Oct 2007
    Bangalore
    did you apply the firmware fix that seagate release for 7200.12?
    Anyways, do agree that seagate hdd's are facing serious reliability issues for past year
  30. #480
    Jul 2006
    Geek's Heaven
    ^^ If I'm not wrong that was for 7200.11 series disks ( as I applied the firmwire fix )
    Who Dares Wins
    Avenging Angel !
  1. what is hardware ID ?
    By mkmkmk in forum QnA (read only)
    Last Post: 14-04-2006, 06:01 PM
  2. a new pc (hardware)
    By champ_rock in forum Hardware Q&A
    Last Post: 24-03-2006, 08:27 PM
  3. Hardware
    By kumarn_2004 in forum QnA (read only)
    Last Post: 15-01-2005, 09:14 PM
  4. All in one hardware??
    By rohanbee in forum QnA (read only)
    Last Post: 27-11-2004, 01:08 PM
  5. hardware course
    By atool in forum QnA (read only)
    Last Post: 30-09-2004, 04:23 PM
