Old 13-03-2008, 08:17 PM   #1 (permalink)
Default Problem with my Hard Disk
Hi,
My hard disk is facing a strange problem.My system gets freezed very frequently.I thought it would be my HDD's problem.Then I connected my hard disk in my friend's PC and booted from it.But the system has no problem.There isnt any freezing problem.
What is the correct problem?Is it related to my hard disk or any other components?
Thnx in advance
anilthomas26 is offline
Old 13-03-2008, 08:40 PM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Problem with my Hard Disk
^it can be RAM or a motherboard problem.
u can test ur ram using a linux cd (ubuntu or knoppix) to run "memtest86+"
praka123 is offline
Old 13-03-2008, 10:13 PM   #3 (permalink)
TechTin.com
ravi_9793's Avatar
Originally Posted by anilthomas26 View Post
Hi,
Thnx in advance
Did you boot in OS installed on your hard disk when connected to your friends PC??
ravi_9793 is offline
Old 13-03-2008, 11:46 PM   #4 (permalink)
Yea I boot into the OS installed on my hard disk .....But there wasnt any problem
Old 14-03-2008, 12:19 AM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
Than it can be overheating or hardware issue??
try another RAM, and check SMPS, processor and cabinet fans.
Hard Disk problem kevin_476 Hardware Q&A 4 24-01-2007 01:58 AM
hard disk problem!!! help lonelychild QnA (read only) 5 30-10-2005 11:43 AM
hard disk problem aditya169 QnA (read only) 6 30-05-2005 08:48 AM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
hard disk problem perk_bud QnA (read only) 3 22-08-2004 11:56 PM
- by c4u
