Old 13-03-2008, 01:01 PM   #1 (permalink)
Default Wide screen monitor
I want to buy a monitor since my monitor gone phut.I have mobo with on board video.(D101GGC).Can a widescreen monitor be connected straightaway or is there any mobo combatibility to checked?.will somebody clarify my doubt?.thanks
joe2005 is offline
Old 13-03-2008, 01:13 PM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: Wide screen monitor
I think all monitors can be considered... i like the DELL monitors... no need for any mobo compatibility
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 13-03-2008, 01:33 PM   #3 (permalink)
Alive Again...
satyamy's Avatar
Smile Re: Wide screen monitor
Yes, You dont need anything else
Just buy a WideScreen LCD and Connect it Directly
your mobo D101GGC will take it without any Problem
almost all P4 and above Boards take Wide Screen
and even PIII and celeron board takes WideScreen
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 13-03-2008, 03:45 PM   #4 (permalink)
Thanks for prompt reply.
joe2005 is offline
Which 19" inch Wide screen LCD monitor to buy?? Rockstar11 Hardware Q&A 80 19-02-2008 02:10 PM
pros & cons of wide screen monitor:- sagardani Hardware Q&A 5 30-11-2007 02:50 PM
Wide Screen Resolution Problems vaibhy_28 Hardware Q&A 5 29-10-2007 12:11 AM
benq 19 inch wide screen lcd or some other?? deepinder_mann1988 Hardware Q&A 4 11-03-2007 06:27 PM
- by c4u
