Old 13-03-2008, 12:17 AM   #1 (permalink)
At Hell's Disq
hellgate's Avatar
Default need a new procy
i need a new procy and i had ordered 4 a E8400 but didnt get it 2night,vendor said he'll be able to get it earliest by Friday night.at present he has ready stock of E2160 & E4500.
my pc will be mainly used or gaming with a HP vp15s (15" LCD) with bits of photohopping,dvd ripping and video editing thrown in.i'll oc anyrocy that i'll buy and i've already got a aBit IP35-E.but if i satisfied with it i'll get a IX38-Quad GT.also i'll be upgrading to Nehalem once it hits the market.
prices of the procies r :
E2160 -> 2600
E4500 -> 4550
E8400 -> 8300
keeping all these things in mind which procy wud u suggest?
plz help me decide.
hellgate is offline
Old 13-03-2008, 12:29 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: need a new procy
If you don't need VT then get E4500.
infra_red_dude is offline
Old 13-03-2008, 12:38 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
no i dont need VT.
i just wanna game.so a E4500 sud do me good till Nehalem arrives.gpu is 8800GTS 320MB and 3*1GB of ram.
hellgate is offline
Old 13-03-2008, 12:52 AM   #4 (permalink)
Wire muncher!
Yea should be enuf if you OC. E4500 should be sufficient.
Old 13-03-2008, 01:01 AM   #5 (permalink)
At Hell's Disq
hellgate's Avatar
main prob is i afaik E2160 & E4500 ont hav any huge performance diff when both r oc'd to above 3GHz.so i'm confused between these 2.
wanted to go 4 E8400 cuz i cud oc it to 4GHz and above.
hellgate is offline
Old 13-03-2008, 01:21 AM   #6 (permalink)
Wire muncher!
Cache sir, cache... thats what matters!
Old 13-03-2008, 01:27 AM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
yup i know cache plays a big part but then i'm downgrading from Q6600.if i look at cache then my best bet is E8400,but i dont think that its full potential will be used.this thing is just getting on my nerves.i just cant decide which one to buy.if only Intel ud release Nehalem by mid 2009 then i wud hav got the E8400 with my eyes closed.
hellgate is offline
Old 13-03-2008, 03:57 PM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
so no 1 else has anything more 2 say?
hellgate is offline
Old 13-03-2008, 06:56 PM   #9 (permalink)
IMO, the safe bet is to go for the less power consuming E8400. I have heard that it can overclock it to about 4GHz very easily.
(Had just read about this: Intel Core 2 Duo E8400 Overclocking Guide)
FYI, the Nehalem Mainstream Desktop processors will be arriving Q1/Q2 2009.
Chk this link:
http://en.wikipedia.org/wiki/Nehalem...re%29#Variants
Even if it arrives say Feb/March, initial prices will be high(assuming). It will take some time for the prices to come down atleast in India. So you would be buying it only around April/May. Thats almost a year by now. You can also read the reviews / cons of the Nehalem processors if any at that time interval.
If your are have budget constraints or not investing more, then you can go for E4500.
If you are still undecided about which to choose, Check out the following links:
E8400, E4500, or E2180?
E4500 overclocked vs Stock E8400
Hope that helps.
shadow2get is offline
Old 13-03-2008, 07:17 PM   #10 (permalink)
darklord's Avatar
E8400 all the way dude !!
I know its expensive but its worth it
darklord is offline
Old 14-03-2008, 09:04 AM   #11 (permalink)
At Hell's Disq
hellgate's Avatar
just 4 testing purposes i've a E2160 running @ 3GHz with 2GB ram and 8800GTS 320MB @ 650|2000|1650.when i'm playing Assassins Creed @ 1024x768 with everything maxed out theres a certain lag in the game which i hadnt faced with a E4500 @ 2.76GHz.so is the E2160 uncapable to fullfill my gaming needs.
also general computing usage doesnt seem to be as pleasureable as it had been with my prev configs.
i've the E8400 lying around (got it frm my vendor yesterday but thought i cud do with E2160 so havent opend the E8400).so sud i install the E8400??
hellgate is offline
Old 14-03-2008, 10:44 AM   #12 (permalink)
Wire muncher!
^^^ Go ahead
Old 14-03-2008, 11:31 PM   #13 (permalink)
At Hell's Disq
hellgate's Avatar
got the E8400 at last.
thnx to all of u for ur help.
hellgate is offline
Old 15-03-2008, 10:59 AM   #14 (permalink)
darklord's Avatar
^^ Lucky you.
Actually i am saying this because all these 8xxx cpus are in short supply, they have already disappeared from US stores. Intel isnt going to let these chips be available in abundance till the channel is cleared of 65nm chips.
So hold tight to your 8400.
I am also sitting tight with my 8400 and 8500, not gonna let them go anywhere.Best part is both clock immensely well.
Play with your 8400 and see how it scales.
Could you tell me the stepping and try for max FSB with dropped multi ?
darklord is offline
Old 15-03-2008, 11:19 AM   #15 (permalink)
At Hell's Disq
hellgate's Avatar
Stepping is C0.as of now i'm running it @ 450 FSB and its running fine.
just ran a 3DMark06 bench with my E8400 @ 4GHz (445 fsb).this is the score:
14061
SM2.0 -> 5952
HDR/SM3.0 -> 6461
CPU -> 3673
r these scores ok or sud i be getting something more?
______
hellgate is offline
Old 15-03-2008, 12:03 PM   #16 (permalink)
darklord's Avatar
That CPU score is very good IMHO.
All Wolfdales are C0 re, tell me the FPO/Batch # on the CPU box.
Keep pushing ! Remember to cool the chipset with a fan or somethin, its passively cooled.It does get warm you see.
darklord is offline
Old 15-03-2008, 01:17 PM   #17 (permalink)
At Hell's Disq
hellgate's Avatar
FPO/Batch # Q748A123
as far as the ram is concerned its a Transcend ram with a Transcend chip.
so sud i continue feeding 2.2v @ 900 @ 5-5-5-15?
it wont boot with 2.1v
hellgate is offline
Old 15-03-2008, 02:48 PM   #18 (permalink)
darklord's Avatar
hmm I know, all their modules have chips with transcend printed over it.Transcend do not manufacture ICs so these are relabelled ones.Take a pic of the sticker on module na.Will make life much easier
darklord is offline
Old 15-03-2008, 03:09 PM   #19 (permalink)
At Hell's Disq
hellgate's Avatar
i'm online on gtalk.
will upload pic in few moments
heres the pic of the ram stick:
hellgate is offline
Old 15-03-2008, 06:20 PM   #20 (permalink)
darklord's Avatar
Looks like Elpida to me. Be careful with voltages dear.
darklord is offline
Old 15-03-2008, 06:26 PM   #21 (permalink)
Google Bot
Pathik's Avatar
darky wat's the max fsb you got on the 8400 on air ? also tell me the max fsb on stock cooling.
Pathik is offline
Old 15-03-2008, 06:38 PM   #22 (permalink)
At Hell's Disq
hellgate's Avatar
u can do 4GHz (445MHz fsb) on stock cooling provided ur case has good airflow.
hellgate is offline
Old 16-03-2008, 12:05 AM   #23 (permalink)
At Hell's Disq
hellgate's Avatar
i'm getting bout 13k for my 4months old XFX 8800GTS 320MB.so i'm thinking of selling it off.
so which card sud i buy in 15k-18k?or sud i hold on till 9800GTX is released?
hellgate is offline
Old 17-03-2008, 10:05 AM   #24 (permalink)
darklord's Avatar
Well frankly i havent clocked the E8400 on Air as yet, under DICE i clocked 582FSB Max on Abit IX38 QuadGT.
Once both my TRUEs arrive, i will do some AIR benching, will try max FSB on air then.
If you have a budget of 18k, bump it a bit and get 3870X2 or else 8800GT @ 12-13k.
darklord is offline
Old 17-03-2008, 10:51 AM   #25 (permalink)
At Hell's Disq
hellgate's Avatar
wil my Coolermaster Extreme Power Duo 650W handle the 3870X2??
hellgate is offline
Old 17-03-2008, 11:04 AM   #26 (permalink)
darklord's Avatar
it should, but i dont think you will be able to clock much.
darklord is offline
Old 17-03-2008, 11:08 AM   #27 (permalink)
At Hell's Disq
hellgate's Avatar
then i dont think i'll buy that.it all depends on whether i'll get a buyer 4 my present psu or not.
hellgate is offline
Need mobo n procy.urgent sonu1983 Hardware Q&A 8 05-01-2008 02:24 AM
Mobo + Procy Chirag Hardware Q&A 2 22-12-2007 12:31 PM
Mobo + procy max 10k The Day Walker! Hardware Q&A 1 10-10-2007 02:15 PM
Buying AMD 939 pin Procy xbonez Hardware Q&A 6 16-09-2007 05:41 AM
which mobo, procy? xbonez Hardware Q&A 6 06-05-2007 02:04 PM
- by c4u
