Old 12-03-2008, 10:51 PM   #1 (permalink)
Unhappy Unexpected reboot after changing the RAM
Dear friends,
I replaced faulty RAM 512MB DDR2@533 to 1GB DDR2@667. But the system reboots unexpectedly. Is this a reason for the problem or something else? Plz help!
Pentium D820 2.8GHZ, Intel D102GGC2 Mobo, IDE 40 GB Samsung
spp_itim is offline
Old 13-03-2008, 12:02 AM   #2 (permalink)
I M A *STAR*
saqib_khan's Avatar
Default Re: Unexpected reboot after changing the RAM
Clarify pls, does ur system has only 1gb 667mhz ram?
And at which state ur pc is restarting? I mean after logging on or where?
Blogging at:
Technostarry
saqib_khan is offline
Old 13-03-2008, 09:51 AM   #3 (permalink)
khansaqib
It has only one module ie 1GB DDR2 @667. The system reboots while using any application Firefox/Wordprocessor/PageMaker etc after 10-15 min or more. Once it reboot just after login screen. I noticed it once reboot when it was even idle.
spp_itim is offline
Old 13-03-2008, 10:22 AM   #4 (permalink)
ancientrites's Avatar
one of the files is missing or a virus.Again reformat your pc(best solution).
asus psn32-e sli,1x4 ddr2 ram,nvidia stacker case,19inch lcd,sapphire hd4850 graphic card,smps 730 w from zeb
asus g73jh lappy
ancientrites is offline
Old 13-03-2008, 10:24 AM   #5 (permalink)
Think Zen.
ray|raven's Avatar
Looks like RAM is faulty.
Use Memory Test(Present on most linux cd's , like Ubuntu).
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 13-03-2008, 10:29 AM   #6 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
load default bios settings, insert ram in other slot , run memtest.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 13-03-2008, 10:35 AM   #7 (permalink)
parthbarot's Avatar
I don't think its a problem of new RAM. otherwise it can hang down in boot process or even can't boot sometimes...
May be the slot is loose?
Just remove and re-attach your RAM.
And check your PC for any virus or spyware things...
Paarth.
www.techlads.com
Paarth.
parthbarot is offline
Old 13-03-2008, 11:26 PM   #8 (permalink)
Thanks everyone for helping me. I restored my system with a previously dump image file. However the system did not reboot for last an hour.
But please tell me whether the RAM frequency may be an issue? My mobo supports 533 or 400 MHz. Is 667 right for my system.
spp_itim is offline
Old 14-03-2008, 12:07 AM   #9 (permalink)
parthbarot's Avatar
This thing is to be checked before you got new RAM slot yaar
i think it will not give any problems... but better you use as per your MB.
Paarth.
www.techlads.com
Paarth.
Automatic and unexpected shutdown chahal63 Open Source 2 01-09-2007 09:54 AM
Unexpected Restarts!!!!!!!!!!!!!!!!!!!!! fazcorp_88 Software Q&A 8 06-03-2007 10:43 PM
Unexpected shutdown problem! eagle_y2j Hardware Q&A 1 06-02-2006 09:24 PM
unexpected shutdown tukaibatman QnA (read only) 7 27-10-2004 12:12 AM
Nero 6…Unexpected Behaviour SHell Software Q&A 3 04-10-2004 06:43 AM
- by c4u
