Old 12-03-2008, 05:59 PM   #1 (permalink)
Talk to the hand!!!
warfreak's Avatar
Default Is 450W enough ?
I have the following PC config:-
Intel Core 2 Duo E4400
2GB Ram
1 DVD RW Drive
2 SATA HDDs
NVidia GeForce 8600GT (BIG)
My PC depends on a 450W rated power supply unit. Currently it is running fine. But will continue to operate trouble free? If not then can anyone please suggest a better PSU ?
Budget < 3K
warfreak is offline
Old 12-03-2008, 06:03 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Is 450W enough ?
if it works fine then it will work fine for long TILL you add any other power hungry hardware.its better to upgrade later..
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 12-03-2008, 06:05 PM   #3 (permalink)
if its operating fine , then why change smps ?
if u want to OC more and have higher rail stability u can go4 cooler master extreme power 500W which costs 3.2k...with this smps you will have no trouble at all even with a 8800GT.
but i see no reason why you should get this smps. . u can buy a new smps when you upgrade next.
for ur config even a zebby 500W pure platinum -1.8k should do , but i hear a lot of people complain about zebronics.
sagargv is offline
Old 12-03-2008, 06:28 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ quite agree
500th post
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 12-03-2008, 07:27 PM   #5 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
If it makes you feel better I have the SAME configuration other than the fact that my Processor is an AMD 4400 and I have a TV Tuner on my system with an XFX 8600 GT , I am using a 450 W SMPS now and it is working fine.
FilledVoid is offline
Ampere rating on the +12V rail of iball 450W PSU? andysmith45 Hardware Q&A 1 14-02-2006 10:52 AM
- by c4u
