Old 11-03-2008, 04:02 PM   #1 (permalink)
Default Best motherboard for E4500
What is the best motherboard for Intel Core 2 Due E4500 procy within 5k price range from Asus / Gigabyte / Intel where i can also OC.
passion_unlimitedd is offline
Old 11-03-2008, 04:05 PM   #2 (permalink)
Dreamweaver
Gigacore's Avatar
Default Re: Best motherboard for E4500
XFX 630i Ultra at 3.3k, XFX nForce 650i Ultra at 4.5k
Choice is your
Gigacore is offline
Old 12-03-2008, 12:18 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
u can also give the aBit IP35-E a try.its a very gud mobo at 5.9k
hellgate is offline
Old 12-03-2008, 02:57 AM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
ASUS P5N-SLI.
MSI P-35 Neo-F.
Both at 5K!
keith_j_snyder2 is offline
Old 12-03-2008, 09:28 PM   #5 (permalink)
If I go for Intel board without OC how will my pc perform and which Mobo shall i take ? Which Intel board is a good Overclocker ?
My PC runs 12 hours daily at a stretch. Will it be a problem to OC as my PC runs long hours daily. Will it harm my Mobo/Procy?
I've never overclocked my procy so I am a little bit worried...
Old 12-03-2008, 11:43 PM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
if u wanna then dont get a Intel original board get a chipset one.
u can run ur pc oc'd for 12hrs or more provided that u hav good cooling.
hellgate is offline
Old 13-03-2008, 11:31 PM   #7 (permalink)
Rising ApocalypsE
Yeah its just a matter of cooling, doesn't matter if u run ur PC 12 hours or 24 hours. Few of my buddies uses a E2160@ 3.4GHz and kept it running for a week!
Best value for money mobo for C2D E4500 ! writealexthomas Hardware Q&A 60 01-04-2008 09:26 PM
Need new P35 mobo for E4500 hellgate Hardware Q&A 16 10-03-2008 05:30 PM
Recommend Motherboards for E2160 & E4500 psmontte Hardware Q&A 8 02-03-2008 11:15 AM
How to OC E4500? New Hardware Q&A 19 30-01-2008 09:02 AM
Which MOBO for Core2 E4500?? Ganeshkumar Hardware Q&A 9 22-11-2007 11:13 PM
- by c4u
