Old 10-03-2008, 11:07 AM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default fx5200 fan not spinning
my gpu - nvidia fx 5200 has developed a problem -the fan has stopped spinning iv cleaned it and all but there seems to be some problem with the fan itself .... does any1 know the contact info of nvidia mumbai i tried the no. given on their site but that doesnt work
http://beingmanan.com
iMav is offline
Old 10-03-2008, 11:12 AM   #2 (permalink)
Wire muncher!
infra_red_dude's Avatar
Default Re: fx5200 fan not spinning
Is the fan removable? Just check out. Most of the low end cards use a removable fan. Jus pop it off and put in your own fan. afaik 5200 can do without a fan.
infra_red_dude is offline
Old 10-03-2008, 11:23 AM   #3 (permalink)
iMav's Avatar
^^ ya its removable, i have removed the fan and will scout for it
i also called up the pune office and asked them and they said that if u taken it from a local vendor u need to go to him u cannot come directly to nvidia
it can do without a fan but the problem is that the display starts going dim and bright; thats when i realized that the fan isnt working
iMav is offline
Old 10-03-2008, 11:25 AM   #4 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
^ its a 3 pin fan? just try inserting into the motherboard aux fan connector to see if it works
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 10-03-2008, 11:27 AM   #5 (permalink)
iMav's Avatar
2 pin ... iv gone a step further im trying to fit the cabinet fan onto the heat sink somehow
iMav is offline
Old 10-03-2008, 11:29 AM   #6 (permalink)
Alter Bridge=GOD
still can be tested on the mobo.if you have a 80mm fan try running the card by placing near it
Old 10-03-2008, 01:48 PM   #7 (permalink)
iMav's Avatar
as i was saying:
my gpu has a fan thats more powerful than the cpu and no dimming
iMav is offline
Old 10-03-2008, 02:44 PM   #8 (permalink)
Attitude matters
Ponmayilal's Avatar
Good improvisation. .To get going it is alright, but try and get an original size fan and fix it so that the overall power consumption can be reduced.
Ponmayilal is offline
Old 10-03-2008, 03:50 PM   #9 (permalink)
GaurishSharma.com
gary4gar's Avatar
haha
good job .
gary4gar is offline
Old 10-03-2008, 04:11 PM   #10 (permalink)
can u tell more detailedly how u cud fit that fan ?
sagargv is offline
Old 10-03-2008, 07:21 PM   #11 (permalink)
dOm1naTOr's Avatar
i think he glued it to heatsink.
and for ur info Ponmayilal
a normal 80mm fan consumes max of 4~5W. There are ones with ultra high speeds but normal ones just so light on power consumption.
But the main ploblem will be the noise. The original GPU fan adjusts speed according to the temps, but now ull have to live with the noise[though not much irritating]
[i have a total of additional 4 80mm fans to cool my oced GFX card.]
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 10-03-2008, 07:23 PM   #12 (permalink)
iMav's Avatar
^^ yup glued it to the heat sink ... and no noise very silent fan and really cool
iMav is offline
Old 10-03-2008, 08:06 PM   #13 (permalink)
Attitude matters
Ponmayilal's Avatar
I am not into any deep technical analysis but generally believe that it will be nice if one can restore anything to as much an original condition as possible and if possible.
.......and well, as you said the power may not be significant.
Offtopic
........and I have sometime back read an article that bemoaned people keeping all their electronics in standby. In standby condition they may be drawing very little power, but the article highlighted how many KW ( I do not remember the figure) we can save if all the people shut down their equipments instead of keeping them in standby unnecessarily.
Old 10-03-2008, 09:05 PM   #14 (permalink)
My FX5200's fan stopped working 2 yrs ago.
Just removed it and still going strong. No problems even with DOOM3.
ashnik is offline
Which way is she Spinning for you? s18000rpm Chit-Chat 88 04-02-2008 07:53 PM
Geforce FX5200 d Hardware Q&A 1 20-10-2005 06:26 PM
Should i buy geforce fx5200 anujpant Graphic cards 8 29-08-2005 06:55 PM
will these games run on fx5200 anujpant Gamerz 1 28-08-2005 08:50 PM
The ball has stopped spinning!Please help anomit QnA (read only) 2 21-05-2005 12:34 PM
- by c4u
