Old 10-03-2008, 10:35 AM   #1 (permalink)
Default Sound problem-Please help
yesterday night some box popped up telling me to select the sound evice but i canceled it and selected that do no show again.Now i am not getting any sound on XP.i have tried reinstalling,upgrading drivers,plugging out and in the cables etc etc but nothing seemed to work.
I have Logitech hdphns.ufortunately only logitech is marked on them no model no.
I have ASUS Supreme audio FX.Plzzzz help guyz
SunnyChahal is offline
Old 11-03-2008, 02:29 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Sound problem-Please help
Try re-installing your os and then install the drivers
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 11-03-2008, 03:54 PM   #3 (permalink)
Search for Adventure
ITTechPerson's Avatar
reinstalling the o/s is the last u can do? before tht try to uninstall the audio driver & re-install from mobo cd - then plug in & out the speaker jack twice it will give u the poup again.
Nobody is Perfect. I am "Nobody"
ITTechPerson is offline
Old 11-03-2008, 04:00 PM   #4 (permalink)
Elevating Humanity
The Conqueror's Avatar
1. Right click My Computer and click properties.
2. Then go to the Hardware Tab
3. Click Device Manager
then right click any thing with yellow exclamation mark
and click Update Drivers.
Regards,
The Conqueror
The Conqueror is offline
Old 11-03-2008, 09:40 PM   #5 (permalink)
Elevating Humanity
Problem Solved ?
Regards,
The Conqueror
Old 11-03-2008, 11:07 PM   #6 (permalink)
yea.solved
Sound Problem in XP hayabusa_ryu Software Q&A 6 31-01-2008 03:45 PM
Sound Problem with Nvdia onboard Sound (hda-intel) Maverick340 Open Source 4 18-09-2007 11:12 PM
A sound problem! pakkasir Hardware Q&A 2 08-05-2006 10:11 PM
Sound Problem zodiac_511 QnA (read only) 11 28-08-2005 10:05 PM
- by c4u
