Originally Posted by dude1x2
Anyone knows why there are yellow spots on my monitor,ie,before the computer boots when it will display
xp
Almost like this(i think u understood).there i saw yellow markings on where its written xp(not much noticeable) and where its written Microsoft Corporation.
microsoft
microsoft would like this in my monitor when Xp boots
Its a loose connection problem. About an year ago, the same problem happened with my monitor. Though yours is only spots, I had my whole screen yellow!
I Took the monitor to a technician and told him to replace the connector and it solved the problem.
BTW, do you get the initial BIOS/CMOS screen also yellow somewhat ?
If yes, then you have the same trouble which I have. Else, test the monitor on another PC, and if the same problem repair your monitor.
