Old 09-03-2008, 11:01 AM   #1 (permalink)
Arun the Gr8's Avatar
Question Need Wireless Keyboard + Mouse for 2K
guys.. help me out with this...
I am building a HTPC an i need a good set of "wireless keyboard + mouse" for it under Rs 2000. It has to have bluetooth connection rather than infra red. Also it will be better if the mouse is a laser mouse rather than an optical one . Plz mention the no. and type of batteries it requires. Also mention the weight (light or heavy) if you guys have any idea about it.
plz mention the company and the model no. anything 'around' Rs 2K will do
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
Old 09-03-2008, 12:59 PM   #2 (permalink)
The G-Axe Effect
gxsaurav's Avatar
Default Re: Need Wireless Keyboard + Mouse for 2K
Which TV Tuner are you going to use & Which Operating System? Are you buying the Wireless keyboard & Mouse just for controlling the HTPC & WMC?
If its Vista, then buy a TV Tuner with WMC support, you will get a Windows Media Center compatible remote with it. With this you do not need any keyboard or mouse to control the HTPC & WMC from a distance.
The choices will be
WinFast DTV1800 H Media Center Edition (Analog + Digital)
WinFast TV2000 XP Global Media Center Edition (Analog only)
Pinnacle PCTV Tuner Kit for Windows Vista (Analog only)
Another method is using your bluetooth enabled phone to control your desktop, WMC & HTPC like you control using keyboard.
If you still want a Keyboard & Mouse combination then raise your budget, you cannot get a Laser Mouse + Keyboard within Rs 2k.
You can get Microsoft Optical Desktop Elite for Bluetooth, but it is optical mouse based & costs more then Rs 2k.
Another choice is Logitech Cordless Desktop MX 3200 Laser but not bluetooth.
Or you can buy seperately but not in bluetooth. Check in the local market for available solutions.
Graphics & Web Designer - SlideShare
Portfolio & Blog : http://gxsaurav.com
gxsaurav is offline
Old 09-03-2008, 03:00 PM   #3 (permalink)
Smile Re: Need Wireless Keyboard + Mouse for 2K
The choices will be
thanks for d help dude... actually what i am building is not exactly a HTPC. i am actually buying a 21" LCD monitor for my PC so that i can enjoy movies in a big screen rather than my 15" CRT and am lazy enough that i dont want to getup in order to fast forward or stop a movie or music... and hence needed a wireless Keyboard + Mouse set .
by d way wht is d cost of d microsoft n d logitech one... u did not mention them. thanks for d info anyway .
Old 09-03-2008, 10:20 PM   #4 (permalink)
The G-Axe Effect
gxsaurav's Avatar
^^^ The rate differes from city to city, better go to the local market & find out.
Which Mobile phone you got & which OS R U using?
gxsaurav is offline
Old 09-03-2008, 10:41 PM   #5 (permalink)
I dont know why u asked this but i own Nokia 5300 Xpress Music and run Windows XP on my PC. I guess u got ur answers; now tell me why?
Old 10-03-2008, 07:23 AM   #6 (permalink)
M$™ Certified Spammer
entrana's Avatar
try the logitech wireless. costs around 1200. im using it and it rocks!!
Seagate 500gb 7200RPM l Corsair 2*1GB Ram 800mhz l XFX 8800 GTS 320MB Xtreme 650/ 1500/ 950 l Asus P5N-eSLI l Core 2 Duo e6750 l Coolermaster Extreme Power 600watts SMPS l Microtek 800VA Ups l
entrana is offline
Old 10-03-2008, 01:07 PM   #7 (permalink)
The G-Axe Effect
gxsaurav's Avatar
Because you can control your PC, WMC & any HTPC software using your Phone .
Don't buy wireless gear, just buy a bluetooth adapter if u don't have it already & connect your phone as a Bluetooth human interface device.
What is the config of your HTPC? The workstation I m using also acts up as a HTPC, hell...it acts up like anything...
1) Workstation
2) Music Jukebox
3) Home theator (with headphones )
4) Gaming machine...
I use Windows Vista with Pinnacle PCTV Tuner kit for Vista. I got a remote with the TV Tuner using which I can control WMC as the TV Tuner works fine in WMC. I see all my videos & listen to music in WMC now when I m free from a distance of 8 feet (my bad). No need to use a keyboard mouse at all...
If you can't buy all these, then simply buy a bluetooth adapter & I will tell you how to control your computer using the phone
gxsaurav is offline
Wireless Keyboard+mouse naveen_reloaded Peripherals 8 08-12-2008 09:40 PM
Help! Purchasing Wireless Keyboard+Mouse BittooTheBe(A)sT Hardware Q&A 5 15-01-2008 09:45 PM
How much a Wireless keyboard + mouse cost? hafees QnA (read only) 10 19-08-2007 12:36 PM
