Old 08-03-2008, 11:05 PM   #1 (permalink)
Default Monitor problem
I am having a core 2 duo, Nvidia 7300Gt graphics, 1024 DDR2 ram,
When my system boots up, first the Xp symbol shows up and when it is time to go into the OS my monitor goes to stand by mode.(Monitior is LG L1752S)
Then after rebooting many times, maybe even rebooting from safe mode , I enter the OS. Can any one help me???
dude1x2 is offline
Old 08-03-2008, 11:11 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: Monitor problem
check if the cables in your computer are not loose. Especially the harddrive cable and such.
Does the system beep or something like an error code?
Does it boot ok into command prompt?
Life is too short. Have fun.
ilugd is offline
Monitor problem 047 Hardware Q&A 4 19-01-2008 01:13 AM
Monitor Problem bizzare_blue Hardware Q&A 5 12-11-2006 06:41 PM
Monitor Problem winzip Hardware Q&A 10 31-07-2006 01:36 PM
Monitor Problem Panda QnA (read only) 5 18-09-2005 08:11 PM
Monitor Problem hikapil QnA (read only) 7 31-03-2005 07:45 PM
