Old 08-03-2008, 07:50 PM   #1 (permalink)
Default Destroy data from failed HDD..is it possible?
My SATA HDD Seagate has now given up within an year!. I am likely to get a replacement from the company.
However I want to know is there any software or some way to destroy the existing data before I hand it over to the vendor?
Thanks,
patkim is offline
Old 08-03-2008, 08:20 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Destroy data from failed HDD..is it possible?
if its detected by your computer in bios then yes you can
using dos utility called seatools u can erase ur hdd ie. write all zeros to drive-thats the command in the interface
seatools can be downloaded from here-
http://www.seagate.com/www/en-us/support/downloads/seatools/
Apple Macbook Pro 17
nish_higher is offline
Old 08-03-2008, 08:52 PM   #3 (permalink)
Dreamweaver
Gigacore's Avatar
writing zeros will take hell lot of time isn't it? But its the only easy solution
Gigacore is offline
Old 08-03-2008, 09:28 PM   #4 (permalink)
Alter Bridge=GOD
^ yea..a 160 gb hdd takes 22-35minutes in full erase..another way is to connect some 2-3 12v batteries in serial and power the hdd when smoke comes out your job is done..but this option works only with WD..if u do it on seagate u r done - no warranty
Old 08-03-2008, 09:41 PM   #5 (permalink)
if harddisk is undetectable only extreme high magnetic field could wipe data
paid is offline
Old 08-03-2008, 09:52 PM   #6 (permalink)
Alter Bridge=GOD
^ thats not practically possible
@ patkim could you be more specific about your hdd crash?its current state?
Old 08-03-2008, 09:57 PM   #7 (permalink)
Dreamweaver
Gigacore's Avatar
@paid, how about dropping it from 10 feet? and see he if the hard disk is really hard or not?
Dont try those magnetic field stuff, it can damage the platters physically
Gigacore is offline
Old 08-03-2008, 10:16 PM   #8 (permalink)
TheSaint
NucleusKore's Avatar
^Won't damaging it too much void his warranty? Especially external damage?
NucleusKore is offline
Old 08-03-2008, 10:30 PM   #9 (permalink)
Dreamweaver
Gigacore's Avatar
bro, i just said about dropping it for joke. Wanna be a NOTW nominee once again?
Gigacore is offline
Old 08-03-2008, 10:37 PM   #10 (permalink)
Beware of the innocent
ilugd's Avatar
take it to some high tech physics lab and ask them to bomb it in a particle accelerator or something.
particleaccelerator@physics-lab:~$bombardwithelectrons -t 5 -i 9
Particle accelerator exited with status 0: Normal Exit - Data wiped.
Life is too short. Have fun.
ilugd is offline
Old 08-03-2008, 10:44 PM   #11 (permalink)
Dreamweaver
Gigacore's Avatar
just do as nish said, if you try coz other techniques, you will not just destroy the data, but you will destroy the hdd as well.
@ ilugd, what happened to ur big mustache dude? Time to get married?
Gigacore is offline
Old 08-03-2008, 11:02 PM   #12 (permalink)
ilugd's Avatar
/me runs away from Gigacore.
(Dont scare me by talking of marriage yaar)
My friend didn't like my moustache. (If you know what I mean.)
ilugd is offline
Old 08-03-2008, 11:25 PM   #13 (permalink)
TheSaint
Too bad your silly thread got TRASHED.
Old 08-03-2008, 11:39 PM   #14 (permalink)
Dreamweaver
Gigacore's Avatar
^ it was not my thread, it was arsenal's
@ ilugd, lol, i got it
Gigacore is offline
Old 09-03-2008, 05:16 AM   #15 (permalink)
club_pranay's Avatar
but seriously, leaving the hdd in a moderate magnetic field should do the job. the I/O head MFI is .8T. so keeping the hdd in slightly over that for a couple of minutes over it should work!
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 09-03-2008, 11:27 AM   #16 (permalink)
My boot screen is stuck up at 'Verifying DMI pool data'. The HDD is however displayed in the BIOS screen.
patkim is offline
Old 09-03-2008, 11:29 AM   #17 (permalink)
Alter Bridge=GOD
^ before doing that read this-
http://www.computerhope.com/issues/ch000474.htm
Old 09-03-2008, 07:28 PM   #18 (permalink)
nice info nish_higher
@patkim: I suggest since your disk is detectable check all your cables firm & intact then boot through XP Bootable CD & choose Repair then restart & boot from Harddisk if problem solved then fine else Format Hard Disk then run chkdsk for badsectors. If there are bad sectors use disk wipe software to destroy all the data and send harddisk for replacement. If no badsectors present try installing the OS again maybe your problem due to corrupt installation
paid is offline
Old 11-03-2008, 10:05 PM   #19 (permalink)
Initially I felt that HDD is gone.
But thank you all for your inputs, yes ultimately it was the bad SATA cable.
.. after cable replacement it's now booting fine.
patkim is offline
Old 12-03-2008, 05:44 PM   #20 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
ohh thats cool .... u r damn lucky .....
bt if u wanted ur data 2 b safe before giving 2 an outsider ....
* delete ur all ur data >> now its empty
* copy any rubbish files [ur fav movie] --- duplicate it, till its full
thus it will automatically replace ur original data [which is suppose 2 b deleted] .....
hope my solution is right .... i did this while exchanging my old HDD & my vendor was amazed & delighted 2 have some good movies in his hand ....
... W H O T ...
ax3 is offline
Destroy the web Ihatemyself Chit-Chat 11 14-08-2007 07:56 PM
SATA drive failed... Trying to get back my data... logan_657@yahoo.com Hardware Q&A 3 13-01-2007 08:27 AM
destroy Harddrive choklate_007 Hardware Q&A 9 27-11-2006 12:02 AM
Can moisture destroy my p.c???? tango_cash Hardware Q&A 12 27-07-2006 03:58 PM
