| Forum |
#1 (permalink) |
#3 (permalink) |
Hi,
I too had the same problem, however, got it resolved. All you have to do is in BIOS change the drive settings from AHCS to IDE and it should recognize. Lets know if this helps. Regards |
#4 (permalink) |
if it is in RAID, then in all likelyhood it is in RAID1 config - for stability
using unequal HDD capacities will result in RAID recognising the lesser of the 2 capacities as the capacity of the RAID |
#5 (permalink) |
I think this be the prob...lower cap hdd is detected else nothing prob with drivers,,,n hardware recognization...problem is windows can not use it for storage..but detects(as it appears in device manager)
Latest user submitted Finance News from India - http://www.financebuzz.in |
#6 (permalink) |
If you want to use the space of each HDDs individually then arrange them in RAID 0
but u will still b able to use only 160GBs of the 250GB HDD 90 GB will still reman unused |
#7 (permalink) |
The HDD is in Raid O, the files in the HDD are not being seen. In fact the drive does not show up in My comp.
In the device manager it shows up,but doesn't show anything in the volumes, although it contains more than 150gb of data |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| SATA ROCKS : Fujitsu intros first 2.5" 7200 rpm hard drive with SATA 2.5 interface | techtronic | Technology News | 7 | 22-03-2009 11:09 PM |
| Sata-II hard disk working at Sata-I mode | Arsenal_Gunners | Hardware Q&A | 27 | 17-03-2009 10:18 PM |
| kernel-2.6.19 onwards CD/DVD IDE drives are detected as SCSI/SATA like /dev/scd0 | freebird | Open Source | 13 | 13-04-2007 07:29 PM |
| Looking for silent SATA hard drive | parimal | QnA (read only) | 18 | 06-03-2005 01:39 AM |
