| Forum |
#1 (permalink) |
At Hell's Disq
plz dont suggest a Abit IP35-E as my vendor wont be able to procure Abit products.so i'll have to choose from Asus,MSI & Gigabyte.as of now i've got myself a Gigabyte 945GCM-S2C mobo whihc sux big time in oc,hdd and memory performance.so need to get another mobo and i need to order it 2day itself. thnx.
i7 930 @ 4.5GHz on CM N620 | BIG BANG XPOWER | 3*1GB 1333MHz | GTX 470 | 500GB + 320GB | HAF 922 | Silent Pro M 850W | MX3200 Laser | LG LD460 32" fullHD LCD TV | HP DV6 1211AX[/I][/B] |
#3 (permalink) |
At Hell's Disq
cant do that man.cuz no other vendor out here wud give me the same facilities that i get frm him like changing mobos,procies and lappies....
other vendors just wont take back products whose seal has been cut but out here i do watever i wish to.i've changed procies after using it for a week or 2.
#4 (permalink) |
At Hell's Disq
plz help me decide amongst the following combos:
1.i>E4500 + Asus P5K Dlx WiFi ii>E4500 + XFX 680i iii>E4500 + MSI P35 Platinum iv>E4500 + MSI P35 Neo-Combo 2>all the above mobos paired with a E2160 instead of E4500.saves me bout 1.8-2k on the procy. 3.i>X2 4000+ + Gigabyte 61SME-S2L or any other X2 combo. plz help me decide 2day cuz i'm getting it 2morrow. hardware i already hav is 2*1GB DDR2 667,XFX 8800GTS 320MB,4 HDDs,1 DVD RW. i'll oc the procy and main purpose of pc is gaming.also the lower the total combo costs the better.
#5 (permalink) | |
Rebooting
I would say, E4500 + P5N-E SLi
rebooting ChotoCheeta.com |
#7 (permalink) |
At Hell's Disq
@Choto P5N-E SLi has NB heating issues when oc'd,so i'm avoiding it.wat bout the MSI P35 Neo-Combo for 5.9k?is it a gud enuf mobo?
@Pathiks Is the Biostar P35 a good overclocker?
#8 (permalink) | |
Rebooting
#9 (permalink) |
Rising ApocalypsE
MSI P35 Platinum is the best IMHO.
It has got Circu Pipe and sports 1600 FSB. And also 2X E-Sata ports( if u ever gonna use 'em)! Neo Combo has got both memory slots for DDR2 & DDR3! But my vote for P35 Platinum! Otherwise u can order A-bit IP35-E from Yantra or THEITWARES or from www.lynx-india.com
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. |
#11 (permalink) |
At Hell's Disq
wats the max limit upto whihc i can oc the X2 4000+?
@keith_j_snyder2 nows that wat i'm confused bout.i just cant decide as to whihc mobo to buy,P35 Platinum,P35 Neo Combo,P5K Dlx or P5NE-SLi.all i need is to oc the E4500 to 3.4-3.6GHz.
#13 (permalink) |
Rebooting
he has to get his hardware from that vendor only who doesnt have ABiT product
@hellgate Rest a sure, I am running E6600 @ 3.8 GHz onload Stabe 24*7... on extra cooling for NB
#15 (permalink) |
At Hell's Disq
^^^ i dont think i'll buy online.cuz if i buy online i'll hafta pay now but if i buy frm my vendor i'll pay him for the mobo by the end of March.
so i'll hafta choose from: Asus P5K Dlx,P5N-E SLi, MSI P35 Platinum,P35 Neo Combo XFX 680i or get some X2 combo.
#16 (permalink) |
Rising ApocalypsE
Man its upto u whether u are going to use an SLi setup or a X-fire.
If SLi then go for 680i. If X-Fire then P-35 Platinum. If u will use single GPU then also P-35 Platinum. It has got Unique Circular Copper pipes which by far no other company has used. http://www.tomshardware.com/2007/06/...ed/page12.html Also lookup for other motherboards which other digitians has mentioned. Who knows - u might get something better than this! But i 'de still stick to MSI P-35 Platinum. I m using MSI boards for past 2.5 years and recommended to several friends and by far we are pleased with its performance.
#17 (permalink) |
At Hell's Disq
at last talked my vendor into getting me a abit IP35-E.getting it 2morrow.
thnx to all of u for helping me decide.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Best value for money mobo for C2D E4500 ! | writealexthomas | Hardware Q&A | 60 | 01-04-2008 09:26 PM |
| Recommend Motherboards for E2160 & E4500 | psmontte | Hardware Q&A | 8 | 02-03-2008 11:15 AM |
| How to OC E4500? | New | Hardware Q&A | 19 | 30-01-2008 09:02 AM |
| Which MOBO for Core2 E4500?? | Ganeshkumar | Hardware Q&A | 9 | 22-11-2007 11:13 PM |
| MSI mobo or INTEL mobo pls. help | karthik316_2003 | CPU / Motherboards | 10 | 29-05-2005 03:29 PM |
