Old 06-03-2008, 10:26 PM   #1 (permalink)
Default Is there a way change display resolution without losing text sharpness?
Is there a way to reduce the resolution of my 14.1" WSXGA+ display without losing sharpness?
If I reduce the resolution of the display,it makes text edges are no longer clean and crisp. Thanks!
running XP on Lenovo Laptop.
dabster is offline
Old 06-03-2008, 11:19 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Is there a way change display resolution without losing text sharpness?
Why would u like to reduce the resolution ?? I mean 1280x800 is that its ment to run in !! so whats the problem in that resolution ??
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-03-2008, 09:16 AM   #3 (permalink)
At Hell's Disq
hellgate's Avatar
LCDs give the best diplay when run at their native res.for ur disp 1280*800 is the native res.
if u run at any other res than this u'll lose display sharpness.
hellgate is offline
Old 07-03-2008, 10:21 AM   #4 (permalink)
deathvirus_me's Avatar
Use Cleartype text's ..
deathvirus_me is offline
Old 08-03-2008, 12:51 PM   #5 (permalink)
I surely want to reduce Resolution , default is 1440x900. and its definitely small.
Is this the driver problem with LCD's ...? or it can't be rectified at all(Hardware issues.)
Please expand, how can it be of help.
dabster is offline
Old 08-03-2008, 02:50 PM   #6 (permalink)
Wire muncher!
infra_red_dude's Avatar
The native resolution is kinda hard coded into lcd controller firmware. So anything above or below that res. will be all distorted. You can do nothing about that. Why didn't you choose an lcd witha lower resolution?
infra_red_dude is offline
Old 08-03-2008, 05:50 PM   #7 (permalink)
Thumbs up Re: Is there a way change display resolution without losing text sharpness?
Yes ClearType helped.
dabster is offline
Old 08-03-2008, 05:55 PM   #8 (permalink)
Rebooting
Huh ?? Which OS ?? There is option under Windows Xp / Vista which gives you power to enlarge size of ICON / any windows text or any such if you are having problem with reading, reducing the resolution is certainly not the way to do it...
I guess no point of discussing then
rebooting
ChotoCheeta.com
Old 09-03-2008, 03:13 AM   #9 (permalink)
Angry Re: Is there a way change display resolution without losing text sharpness?
Huh ?? Which OS ??
I guess you are just a flow poster on this forum, I added the OS details on the same date when i asked question and I believe that you don't even read the question before answering. wow!
dabster is offline
Old 09-03-2008, 03:19 AM   #10 (permalink)
Arsenal_Gunners's Avatar
Flow poster?What is that,lol
Choto Cheeta is a senior member of the forum,so be a bit respectful.
And anyways your problem is solved.
Arsenal_Gunners is offline
Old 09-03-2008, 11:11 AM   #11 (permalink)
^^^^Hey, Arsenal_gunners I said that Cleartype effect helped, as in the aliasing of text was reduced. so its kind of fine, but still if somebody has another solution, i am open to that. []
By Flow poster, meant to say that 'just replying threads without reading completely'. and then writing a "Huh?"
dabster is offline
Old 09-03-2008, 12:07 PM   #12 (permalink)
Arun the Gr8's Avatar
of course the icon size can b changed and it will help... check this out
http://www.entity.cc/change-icon-size.php
also u can change the font size in XP after changing the resolution :
1. Right Click Desktop + Choose “Properties”
2. In the Properties Window click on the “Appearance Tab” at the top.
3. There in the font size u can have the size with which u r comfortable
New Dell Inspiron 14: Intel Core i3 350 - 2.26 GHz, 2 GB DDR3 1066 MHz RAM, 320 GB 7200 RPM HDD, 512 MB ATI Mobility Radeon HD 4330
Arun the Gr8 is offline
How to Change GDM Resolution In Gutsy Rahim Open Source 13 09-02-2008 11:02 AM
display (resolution) problems srinivasaraor Hardware Q&A 1 31-08-2007 06:00 PM
Screen Resolution Change hailgautam Open Source 24 04-03-2007 03:12 PM
Cant Change Resolution valtea Open Source 4 03-08-2005 10:33 AM
