Old 05-03-2008, 02:57 PM   #1 (permalink)
jerin3013's Avatar
Unhappy Blue Screen Errors With Quad Core System
Configurations:
Intel Q6600
Asus P5K-VM mthbrd
2 GB DDR2 800 MHz Zion Single Ram
320 GB SATA Western Digital HDD
500W Mercury SMPS Cabinet
DVD writer SATA
Problem: My system crashes very frequently with blue sceen Errors.
And If I Unplug Any USB Products It Will Restart Automatically.
Help Me Urgently
jerin3013 is offline
Old 05-03-2008, 04:43 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Blue Screen Errors With Quad Core System
Install the Service Pack One please
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 07-03-2008, 07:53 AM   #3 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Choto, where has the user mentioned that he is using Vista ?
By the way, I feel that SMPS or CPU Cooling might be the culprit.
What operating system are you using ?
http://educations.newegg.com/tool/psucalc/index.html
Use this site to check what SMPS you need.
techtronic is offline
Old 07-03-2008, 09:27 AM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
Help Me Urgently
check whether front pannel usb ports r connected correctly to the mobo.
try to do a clean install of the os ur using.cud be that some os files r corrupt.
hellgate is offline
Old 07-03-2008, 10:40 AM   #5 (permalink)
Rebooting
a real common problem !!!
http://support.microsoft.com/kb/941600
http://support.microsoft.com/kb/925528
there are few more patched which I dont remember now as SP1 comes with all of them to address the issue !!!!
rebooting
ChotoCheeta.com
Old 07-03-2008, 11:15 PM   #6 (permalink)
Hai
I am 3d Vfx composer. At home i buyed a pc
Intel Quad core 2.4GHz 6600
Asus P5KC motherboard
Transcend 2 + 2 , 4 GB RAM dual channel
320 WD 16MB buffer SATA II
VIP 500W SMPS
2 Cooler fans
NVIDIA 8800GT GIGABYTE 512 MB RAM
but i am facing booting problems.
booting is ok
2nd when the os is loading (XP) some time it hangs
Plz give me a solution
what is the reason
yarasu is offline
Old 07-03-2008, 11:58 PM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
Originally Posted by yarasu View Post
Hai
VIP 500W SMPS
2 Cooler fans
booting is ok
what is the reason
it cud be ur smps is a bit underpowered.
hellgate is offline
Old 08-03-2008, 02:12 AM   #8 (permalink)
techtronic's Avatar
WoW, SMPS is definitely underwatt, considering the fact that the Video Card is a 512 MB 800 nVIDIA Monster. Cooling seems to be fine.
Old 08-03-2008, 08:42 AM   #9 (permalink)
Torrent Lover :)
akshaykapoor_3's Avatar
Same prob here as well... Even m using Q6600 PC with DG33FB mobo..
250 GB HD WD
SONY 20X DVD-R
Using XP and Vista Ultimate
3GB Dynet 667Mhz RAM..
Sometimes its "IRQL_Not_Less_Or_equal"/ "BSOD with win32k.sys" or smthng like dat.. I guess the problem is with the RAM..
akshaykapoor_3 is offline
Old 08-03-2008, 10:40 AM   #10 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ ru having probs with both os?wat psu r u using?
hellgate is offline
Old 08-03-2008, 12:34 PM   #11 (permalink)
Torrent Lover :)
^^ Yes .. Actually this would happen very frequently earlier till i got both the RAMs replaced.. Seeing BSOD on the very frst day aftr i purchased my new PC was really sad fr me...
m using iball power supply
Still, i do hav BSOD popping up once in 3-4 days... nd yes it happens in bth OS...vista r XP.. Bt havnt faced dis USB prob as described by jerin3013.. Hw do i get to d cause f dis nw ??...
Old 08-03-2008, 07:02 PM   #12 (permalink)
jerin3013's Avatar
Iam Using XPSP2
Smps or Ram,Whats the Prob?
Quad Core System CRASHING HELP HELP !!! Padikkal Hardware Q&A 29 01-04-2008 09:23 PM
Blue screen appears with different errors and boot option removal guhanath Hardware Q&A 3 05-05-2007 08:16 PM
Intel Responds to AMD's Quad FX System with 8 core procy iMav Technology News 5 09-01-2007 03:49 PM
Intel ships first quad-core Core 2 Extreme QX6700 sabret00the Technology News 4 15-10-2006 12:14 PM
Move over Core Duo.. Quad core is here anispace Technology News 2 29-06-2006 12:25 AM
- by c4u
