Old 05-03-2008, 10:51 AM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Audio Cassette to Audio CD Converter ? (Urgent Please)....
I (my Friend) have 3 Audio Cassette, want to convert them into CD so I can Play it tommorrow in occasion of ShivRatri
Can anyone tell me the name of device ?
and what will be its cost ?
their are only 3 cassette so if the device is costly, than is their (any shop) anyone in mumbai who can do this ?
Please let me know bcoz i have to convert it today only
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 05-03-2008, 10:53 AM   #2 (permalink)
Default Re: Audio Cassette to Audio CD Converter ? (Urgent Please)....
Just connect any walkman or casette player to the audio in port of your computer with cable having 3.5mm(as in headphones on one side) jack on both sides and record casette in your computer using a software like audacity. Then write it to cd converting to any format you want. Why buy a device for converting just three casettes? But if you want its available
ThinkFree is offline
Old 05-03-2008, 11:09 AM   #3 (permalink)
Alive Again...
satyamy's Avatar
thanks for the help
i also got this article
http://www.andybrain.com/archive/con...cd-digital.htm
but unfortunatley i dont have any player or walkmen
also if i buy any of them than it will be costly
is their any other option ?
satyamy is offline
Old 05-03-2008, 11:40 AM   #4 (permalink)
Sangeet Premi
2kewl's Avatar
Get a walkman or a player from a friend and record it using Audacity. It's the best way. You can later burn the MP3's into a CD
2kewl is offline
Old 05-03-2008, 04:47 PM   #5 (permalink)
Fullbring
Zangetsu's Avatar
U can also use musicmatch jukebox plus...I had read this tutorial on digit mag
quite a year ago...i dont remember
Zangetsu is offline
Old 06-03-2008, 04:15 PM   #6 (permalink)
Music match juke box is the software.I used it.
ra_sriniketan is offline
Old 06-03-2008, 05:37 PM   #7 (permalink)
ajayritik's Avatar
Even I used Music Match Juke Box. I would suggest you to search if you can get a CD of the same collection. I'm sure the price may not be that much.
ajayritik is offline
Old 06-03-2008, 06:10 PM   #8 (permalink)
I too used music match jukebox. But walkman/cassette player is something required here. If not then c if any friend of yours has a MP3 player with line-in recording. I have used my iRiver MP3 player to record through cassette player. The MP3 player converts the music directly into MP3 so no conversion software is required (but you will still require software for your MP3 player to transfer music :l )
AMD Phenom II X4 955 BE, Asus M4N98TD EVO, 2x2 GB G.Skill @ 1600MHz, MSI GTX 560Ti Hawk, 500GB Western Digital Black SATA-II, Dell Ultrasharp U2311H, CM 690, Corsair VX550
monkey is offline
Old 06-03-2008, 07:45 PM   #9 (permalink)
Alive Again...
satyamy's Avatar
Thanks For Help
I borrowed Walkman from my friend and Converted it
Thanks again
satyamy is offline
A good Audio Converter moshel Software Q&A 17 04-02-2009 05:48 PM
good mp4 audio converter pls... dinesh_mettur Mobiles and Tablets 3 30-12-2006 12:14 PM
Audio 5.1 channel converter chandruxp QnA (read only) 4 30-04-2006 05:29 AM
high quality sound recording from audio cassette stalin Hardware Q&A 3 01-04-2006 11:03 PM
need an audio converter for converting real audio to mp3 asdf1223 QnA (read only) 3 18-09-2005 08:32 PM
- by c4u
