Old 04-03-2008, 01:52 AM   #1 (permalink)
Default lancard problem!!!!
pals...
i needed to shift my office pcs 2 gbps lan...
so i got lan cards.....
installed all the lan on all the pcs...
but on 1 pc....
as soon as i fit the lan card, the system doesnt starts...
nothing happens, when i click on the power button...
and again if i remove the card, the system starts.......
tried with other normal lan cards,,,,,(10/100) and the system starts normally...
but with these cards,,,(10/100/1000,(SVB International) the system doesnt start at all....
but all the cards working well...on the rest of the 6 pcs.....
the mobo..is... ASUS A8V-MX
have checked 2 diff. pci slots...
also upgraded the bios...
but same prob...
10/100 lan card works,, but not 10/100/1000 lan.....
system doesnt power on....
help needed pals...
The Day Walker! is offline
Old 04-03-2008, 07:48 AM   #2 (permalink)
dOm1naTOr's Avatar
Default Re: lancard problem!!!!
is PCI clocks set to default? try setting it below normal
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-03-2008, 10:01 AM   #3 (permalink)
@ dominator,
would that help as other cards work perfectly...only this gigabit card doesnt work...
but well will that a shot 2...
thanx
angel
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
lancard not detected engineer Software Q&A 1 22-09-2006 05:45 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
if in server have 2 lancard so how can i double my lan speed pr@k@sh Networking 2 22-03-2005 11:54 PM
- by c4u
