Old 03-03-2008, 01:24 PM   #1 (permalink)
Default More RAM Decreased Performance ???
ive been running my 8800 gtx, with a 320 gb WD Hd, Asus P5b Mobo, intel e6400 2.13 ghz, and 2 gb of OCZ PC 6400 800mhz ram ... the 3dmark 06 score i was getting with this was 8919 .... i bought another gig of exactly the same OCZ ram and since then ive been getting about 8600 3d marks, also in my windows experience index, the RAM sub score has gone down from 5.1 to 5.0 ...... i dont get why... the only other changes to my system have been to the case and PSU.... and my cpu does run a few degrees higher than it did earlier.... so what could be the reason ??
rsingh is offline
Old 03-03-2008, 01:29 PM   #2 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
Default Re: More RAM Decreased Performance ???
did you break a previous dual channel configuration ? Because breaking dual channel decreases speed.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 06-03-2008, 01:18 AM   #3 (permalink)
did i break a previous dual channel configuration ... ? i really dont know... i had 1+1 and i installed a 3rd stick of 1 gb ... does that mean i broke the dual channel ? and wat shud i do to increase the speed ? can u plese explain ?? thanks
rsingh is offline
digit ALEXA ranking decreased krates Random News 9 01-03-2008 10:58 AM
Best performance from RAM mananknl Hardware Q&A 6 06-12-2006 10:26 PM
what will be the performance 56561 Hardware Q&A 8 02-10-2006 02:05 PM
PC performance Trinity Software Q&A 1 25-03-2006 09:49 AM
- by c4u
