Old 03-03-2008, 12:37 PM   #1 (permalink)
Alive Again...
satyamy's Avatar
Question Vista Hangs on using Dialup Connection from Modem
My Friend has a Dual Core (E2160) with Intel 945GCNL Board
and 56K Motorola Internal Modem
Running Windows Vista Ultimate
He is in Mumbai
Uses MTNL Dialup Connection (dial to 172231) to connect to Internet
while dialing Out of 20 attempts in 19 His PC gets hangs
This works fine on WinXP and Win98
but only prob is in vista ?
can anyone guess, wht can be the prob ?
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 05-03-2008, 03:51 PM   #2 (permalink)
Proud to be Linux
abhinandh's Avatar
Default Re: Vista Hangs on using Dialup Connection from Modem
may be due to lack of driver support.try using latest driver.
http://abhinandh.com
abhinandh is offline
Old 05-03-2008, 04:40 PM   #3 (permalink)
Rebooting
Choto Cheeta's Avatar
in that case it would hang on 1st attempt
why would it need to dial 20mins i mean, is not it getting connected ?? if yes then increase the Dialling attempts from 20 to 99 may be !!!
rebooting
ChotoCheeta.com
Choto Cheeta is offline
633 error on dialup connection DR RANJAN Software Q&A 6 10-11-2006 08:54 PM
Dialup connection slowdown????? rakeshishere QnA (read only) 5 07-07-2006 06:06 AM
help me setup a smartlink dialup modem and connect via sancharnet dialup prashanthnbhat Open Source 4 26-06-2006 04:15 PM
bsnl dialup connection Broadband and DTH 7 18-11-2005 12:14 PM
Reason for sound when using Dialup N Modem?? prasathvishnu Networking 5 06-11-2004 01:04 PM
- by c4u
