Old 02-03-2008, 10:09 PM   #1 (permalink)
Angry Quad Core System CRASHING HELP HELP !!!
My new system crashes very frequently with blue sceen.
Could not use the system due to failures, loosing DVDs & CDs.
Installed XP on drive D: Installed Vista on Drive J: Same condition repeates.
Config:
Intel Q6600
Inel G33 FBC
2 GB DDR2 800 MHz Transcent 5-5-5 Single strip
160 GB SATA Seagate (D-20, F-10, G-40, H-40, I-20, J-40)
40GB PATA Maxtor OLD (C-20, E-20)
400W iball SMPS Cabinet
DVD writer SATA
1. Re-Installed Xp,
2. Inserted memory in another slot,
3. Updated BIOS,
4. Removed the OLD HDD(40 GB).
5. HDD SATA port changed
Kindly Help !!!
Similar postings are searched, Could not find proper reply.
Padikkal is offline
Old 02-03-2008, 10:26 PM   #2 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
Default Re: Quad Core System CRASHING HELP HELP !!!
is it overclocked?
i think its got some trouble with the ram or power supply.most likely its the ram.try changing the ram.i think u'll get instant replacement since its a new system though that depends on ur vendor.
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 02-03-2008, 10:38 PM   #3 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
have you checked your motherboard temperature ? What about viruses ? Have you tried installing Vista on C Drive ? Do you even need XP ?
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 02-03-2008, 10:59 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
Power Supply seems the most probable culprit. RAM mebbe the other. Measly iBall 400W PSU for that system?!!!
infra_red_dude is offline
Old 02-03-2008, 11:36 PM   #5 (permalink)
The Smaller Bang
^^good point. me too had a PSU problem a month back.
Old 03-03-2008, 12:15 AM   #6 (permalink)
Angry Re: Quad Core System CRASHING HELP HELP !!!
Not overclocked.
RAM test works normally, no errors.
SMPS of 400w not sufficient?
Padikkal is offline
Old 03-03-2008, 12:52 AM   #7 (permalink)
Wire muncher!
1) Test RAM with memtest86.
2) Plug in another spare supply and then test.
Quad core system, 2gb ram, dg33, 2 hard disks, 1 optical drive and only 400w smps that too iball etc.? their efficiencies are quite low. So you do not actually get full 400w outta it.
Old 03-03-2008, 08:24 AM   #8 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Yup.. It will be more like 200W Test with another decent SMPS and then see
kalpik is online now
Old 03-03-2008, 10:33 AM   #9 (permalink)
Alter Bridge=GOD
change the PSU and try changing the ram.not putting it in another slot but replacing it with some other ram.may i know the +12v current written on the sticker of your PSU? it would be something like +12V 20A..
Old 03-03-2008, 11:27 AM   #10 (permalink)
Wire muncher!
^^^ those printed things are just an eyewash.
Old 03-03-2008, 11:39 AM   #11 (permalink)
You gave been GXified
gxsaurav's Avatar
Get atleast 500W colorsit or other reputed brand. If it is printed 500W then the real throughout put should be 400W. I wrote a thread long before about how to calculate full output.
about.me/gxsaurav
gxsaurav is offline
Old 03-03-2008, 11:46 AM   #12 (permalink)
Web developer
narangz's Avatar
Which PSU comes in 'good' category? The only ones available here are Intex, Frontech(Even these are chinese ) & other unknown Chinese crap. iBall is a scarce thing here. They are available but those dealers are robbers
How do you calculate the required power for a system?
I've this config:
Asus M2NPV-MX
AMD 64 X2 3800+ Windsor 90nm
512*2 Kingston 667 Value RAM
DVD Writer
CD Writer
1 PATA 40GB HDD
1 SATA 160 GB
3 fans
I've Intex 400W PSU. Couldn't find anything better. I know its not even 400W So what should be the PSU wattage in my case & which PSU manufacturer you recommend?
P.S.- It is not OCed & I rarely play games.
narangz is offline
Old 03-03-2008, 02:04 PM   #13 (permalink)
Alter Bridge=GOD
^ ur config will need a new PSU when you add a gfx card.your current PSU will work atm
Old 03-03-2008, 02:40 PM   #14 (permalink)
Quad core isnt a problem for sure!! have been using it for 2 months now without any hassles.
1st cause of BSOD's is virus,then maybe pirated OS,RAM issues and if none above then SMPS should be dumped.
I suffered such BSOD's on my P-rated Vista and got such bsod's even after reinstalling a dozen times.
I think u r using a P-rated OS.(no offence meant) just try installing linux on ur pc and then try
SunnyChahal is offline
Old 03-03-2008, 11:09 PM   #15 (permalink)
Tested with MemTest-86 v3.4. All tests are passed except following
Test 6 [Moving inversions, 32 bit pat] - Lot of error, hanging
Test 7 [Random number sequence] - Errors 130.
I purchased it some 20 days back, first day onwards problem is there.
SMPS written 12V 17A
Whether the Memory is the real culprit?
Details about this error @ http://www.memtest86.com/tech.html
Padikkal is offline
Old 03-03-2008, 11:53 PM   #16 (permalink)
mayanksharma's Avatar
Did you run memtest86 with 2GB plugged or with single 1GB sticks one by one? Unplug any one of the sticks and then repeat the same accordingly. And even if the errors continue to appear, then yes ur RAM is faulty. Get it changed. One more thing, CoolerMaster Extreme series PSU 300W or 400W would be suitable for ur pc. The CM 300W PSU price tag is around 1200 bucks.
mayanksharma is offline
Old 04-03-2008, 08:03 AM   #17 (permalink)
I am having single strip. 2nd 2GB planned for later purchase.
Padikkal is offline
Old 04-03-2008, 07:03 PM   #18 (permalink)
darklord's Avatar
Memory could be faulty and also change the PSU. QUad draws a lot of power dear
darklord is offline
Old 04-03-2008, 08:59 PM   #19 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
I feel the psu is the main culprit here....... 400W for quad core?????? i use a 450W one for Pentium D
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 04-03-2008, 09:44 PM   #20 (permalink)
try with some other ram stick and see if bsod's occur again. .but u should change ur psu even if ram turns out to be faulty.
sagargv is offline
Old 04-03-2008, 09:58 PM   #21 (permalink)
My Amd athlon x2 3800+ system was also crashing on an iball 400W PSU!
Its the PSU, get urself a 500W PSU.
Xccentricity is offline
Old 28-03-2008, 11:36 PM   #22 (permalink)
Smile Re: Quad Core System CRASHING HELP HELP !!!
My Problem had been solved. The brand new-sealed Transcend 2GB DDR2 RAM replaced. The memory test is successful with no errors.
Thankz for all replies, advices.
Padikkal is offline
Old 28-03-2008, 11:52 PM   #23 (permalink)
rahulmig's Avatar
Change ur PSU and rAm ...
Dealers in EVGA,MSI,Corsair,Paliet Products,OCZ Memory ,Tagan SMPS & Many More
We are Authorized partner for ESET Products
Call me @ 9870803001
rahulmig is offline
Old 29-03-2008, 10:48 AM   #24 (permalink)
Web developer
narangz's Avatar
That's great
narangz is offline
Old 29-03-2008, 12:13 PM   #25 (permalink)
Hostage Negotiator
nithinmohantk's Avatar
Config:
Intel Q6600
Inel G33 FBC
DVD writer SATA
1. Re-Installed Xp,
3. Updated BIOS,
Kindly Help !!!
Powersupply man. change the power supply(SMPS).. 400 W IBall will deliver a maximim of 300W only.. So it's not efficient enough to work with Quad cores buddy..
4 Cores need more power..
More Power needs a better PSU.. go for a 500W or 600W Cooer Master .. coller Master Extreme 500W will cost 2850/- @ www.primeabgb.com
Hostage Negotiator
You are surrounded by simple, obvious solutions that can dramatically increase your income, power, influence and success. The problem is, you just don't see them.
nithinmohantk is offline
Old 30-03-2008, 08:19 PM   #26 (permalink)
Fast 'N' Furious
topgear's Avatar
it's good to heard that your problem had solved. But pal do change the psu to atlest 500W one . Look for brands like antec, corsair, coolermaster, transcend. It's important for your proc and should give you better room for future upgrade like a gfx card for gaming -as g33 core is not very good for gaming.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 31-03-2008, 01:40 AM   #27 (permalink)
I s33 G33ky p30pl3
Cool Re: Quad Core System CRASHING HELP HELP !!!
The PSU is the culprit.. Change it immediately before it does some serious damage to your system. in my opinion get yourself Cooler Master Extreme Power 600W costs within Rs. 4000. its gives value for money and performance, i don't know the price exactly its good and powerful enough to provide juice for your setup.
shivg33k is offline
Old 31-03-2008, 01:53 AM   #28 (permalink)
darklord's Avatar
The thread starters problem is solved, why is everyone still posting solutions ?
darklord is offline
Old 01-04-2008, 01:00 PM   #29 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ I think to save him from his future problems
topgear is offline
Old 01-04-2008, 09:23 PM   #30 (permalink)
ace
hiii
you can use this site to find out the right power supply for ur system
http://www.extreme.outervision.com/p...ulatorlite.jsp
ace is offline
Quad Core & HDDs The Unknown Hardware Q&A 4 26-03-2009 10:55 PM
Intel Responds to AMD's Quad FX System with 8 core procy iMav Technology News 5 09-01-2007 03:49 PM
Intel ships first quad-core Core 2 Extreme QX6700 sabret00the Technology News 4 15-10-2006 12:14 PM
Move over Core Duo.. Quad core is here anispace Technology News 2 29-06-2006 12:25 AM
- by c4u
