Old 02-03-2008, 05:57 PM   #1 (permalink)
Default Networking and Proxy
Here is the Situation :
I have 10 computers and all in LAN.
C1,C2,C3,C54,C5,C6,C7,C8,C9,C10
All computers , except 3 computers(C5,C8,C9) , are getting Broadband Internet through second Lan Card.
(C5,C8,C9) do have second lan card.
Now, I want
C5 to share internet with C1
C8 to share internet with C10
C9 to share internet with C2
Kindly guide me
kolucoms6 is offline
Old 02-03-2008, 10:10 PM   #2 (permalink)
mekalodu
iinfi's Avatar
Default Re: Networking and Proxy
well man i m no good at this ...
jus trying..
assuming you are using win XP
in your lan card under TCP/IP settings in the "Preferred DNS server"
for C5 put the IP address of C1
for C8 put the IP address of C10
for C9 put the IP address of C2 ...
i dont know whether this wud work ... i have never networked more than 2 PCs ...
mekalodu
iinfi is offline
Old 02-03-2008, 10:20 PM   #3 (permalink)
Only DNS will do ?
No IP Required ?
Old 03-03-2008, 07:14 AM   #4 (permalink)
mekalodu
iinfi's Avatar
well yes .. u will need to assign each of the computers an IP address...
i m not sure whether it will be assigned a dynamic IP...
make sure the computers are in the same domain/workgroup
mekalodu
iinfi is offline
Old 03-03-2008, 12:22 PM   #5 (permalink)
No SERVER.
C1: 172.16.0.1
C2: 172.16.0.2
and Like wise.
As in DNS server setting,
C5 as 172.16.0.1
C8 as 172.16.0.10
C9 as 172.16.0.2
Right ?
and How to make it shared for Internet ?
means, how C5 will get Internet from C1 ?
Do I need to install some Proxy server on C1 ?
Old 03-03-2008, 04:59 PM   #6 (permalink)
mekalodu
iinfi's Avatar
Now, I want
Kindly guide me
in your first post ...
u have said "(C5,C8,C9) do have second lan card."
did u mean to say ... "do have second lan card." OR "do NOT have second lan card."
are you using simple cross wire cable to connect each computer with the next??
C5 as 172.16.0.1
C8 as 172.16.0.10
C9 as 172.16.0.2
Right ?
this looks correct ... u will need to make your broadband internet connection a shared one (jus as you share files and folders). now your windows firewall mite create issues in file and internet sharing. try disabling them within your LAN and try if you are able to share internet the way you want.
mekalodu
iinfi is offline
Proxy Chirag QnA (read only) 15 13-08-2007 12:27 PM
need proxy ra_sriniketan QnA (read only) 1 03-07-2006 11:25 PM
Proxy pratheesh_prakash QnA (read only) 2 19-02-2006 02:29 PM
Proxy.......... Help khattam_ QnA (read only) 13 28-03-2005 03:29 PM
- by c4u
