Old 02-03-2008, 11:26 AM   #1 (permalink)
Super Saiyan
Goten's Avatar
Red face Want Webcam Drivers - Plz Help
I got this webcam from Enter. I dont have drivers for it. I got windows xp home installed. Pls help me out coz I dont want to waste nemore on webcam.
Here is a pic.
I appreciate ur help n will do the same if u need it.
Peace brothers~~~!
Goten is offline
Old 02-03-2008, 01:02 PM   #2 (permalink)
Default Re: Want Webcam Drivers - Plz Help
Try http://www.driverguide.com/
ThinkFree is offline
Old 02-03-2008, 01:34 PM   #3 (permalink)
TheSaint
NucleusKore's Avatar
Download SiSoft Sandra Lite from here
http://www.sisoftware.net/index.html...uy&langx=en&a=
and probe your camera and tell me what webcam it is, the details
NucleusKore is offline
Old 02-03-2008, 01:40 PM   #4 (permalink)
Super Saiyan
Goten's Avatar
Exclamation Re: Want Webcam Drivers - Plz Help
Originally Posted by asnvin View Post
Thanks for ur help but I have already tried that.
Peace~~~!
Goten is offline
Old 02-03-2008, 07:26 PM   #5 (permalink)
Super Saiyan
Goten's Avatar
Here is the result.
I hope it will help.
SiSoftware Sandra
General Information
Controller : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Root Hub
Compound Device : No
Hub Is Bus Powered : No
Power Switching : None
Over-current Protection : Individual
Number of Ports : 2
Root Hub: USB Port 1
Status : Device Connected
Device Connected to Port
OEM Device Name : Pixart Imaging, Inc. Easy Snap Snake Eye WebCam
Device Version : 1.00
Device ID : VEN_093A, DEV_2468, PRT_FF
USB Version : 1.10
Speed : Full (12Mbps)
Configuration Settings : 1
Data Packet Size : 8bytes
Root Hub: USB Port 2
Status : No Device Connected
Peace Bro~~~!
Actually i found the driver myself.
But it is not actually wat i want although its working.
So if u wanna try n help me out then do so or relax.
Peace~~~!
Goten is offline
Old 02-03-2008, 11:19 PM   #6 (permalink)
TheSaint
Use this driver
http://www.pc210.com/download/downnow.asp?id=49
and if that doesn't work try this
http://files.filefront.com/STD3+3Nex.../fileinfo.html
Help:: need drivers for VISTA HUAWEI smart AX MT841 drivers sudheer17682 Software Q&A 6 30-08-2008 07:19 AM
Please help me! I need drivers demoninside9 Software Q&A 4 26-08-2007 03:04 AM
Help with Drivers Suhas M Software Q&A 8 03-02-2007 03:34 PM
Drivers for Win XP SP2 nishant_nms Software Q&A 6 01-12-2005 12:00 AM
- by c4u
