Old 01-03-2008, 10:27 AM   #1 (permalink)
Fullbring
Zangetsu's Avatar
Default AMD or Intel !!!
Hi Guys,
I m confused between AMD & Intel processors ???
which is best now from above 2...??
could somebody give me the detailed comparison table of both...
mentioning there features & prices & obviously ranking
Zangetsu is offline
Old 01-03-2008, 11:01 AM   #2 (permalink)
dhanusaud's Avatar
Default Re: AMD or Intel !!!
I say Intel. Use C2D or QC for better performance.
my blog http://www.dhsthemes.blogspot.com
themes for symbian phones
dhanusaud is offline
Old 01-03-2008, 11:05 AM   #3 (permalink)
Google Bot
Pathik's Avatar
Depends on your budget. For very cheap systems, I prefer AMD. For Mid-High configs Intel C2D/C2Q.
Pathik is offline
Old 01-03-2008, 02:03 PM   #4 (permalink)
dhanusaud's Avatar
I think karan was asking abt gud processor. If you really want cheap processor try CD or PD. Both are dual core processor from intel.
Old 01-03-2008, 04:24 PM   #5 (permalink)
dOm1naTOr's Avatar
CD and PD are total waste. PD heats like hell and consumes very much power and marginally much lower in performance and is beaten even by X2.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 01-03-2008, 04:33 PM   #6 (permalink)
-----ATi-----
nvidia's Avatar
Go for AMD only if your budget is less. If you are a gamer and if youre looking for very high performance then go for Intel.
http://twitter.com/akshayms
nvidia is offline
Old 01-03-2008, 04:57 PM   #7 (permalink)
Fullbring
Zangetsu's Avatar
Ya but pls give me a performance table of both intel & amd or may be a
weblink 2 see the overall comparisons if its possible.....
Zangetsu is offline
Old 01-03-2008, 05:01 PM   #8 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
http://www23.tomshardware.com/cpu_2007.html
from the drop-down list,choose the proccys u wanna compare
Apple Macbook Pro 17 :cool:
nish_higher is offline
Old 01-03-2008, 05:01 PM   #9 (permalink)
-----ATi-----
nvidia's Avatar
^^Whats your budget just for the processor?
nvidia is offline
Old 01-03-2008, 05:23 PM   #10 (permalink)
Fullbring
Zangetsu's Avatar
which is the latest in AMD series proc ?
cause i dont have any knowledge abt AMD proc,only know intel series order...
Zangetsu is offline
Old 01-03-2008, 07:00 PM   #11 (permalink)
UBERGEEK
PCWORM's Avatar
Tell ur budget!! it will b easy to decide between options.
PCWORM is offline
Old 01-03-2008, 08:08 PM   #12 (permalink)
speedyguy's Avatar
1st f all wat r u lukin at it for....a desktp or notebook....n ofcourse in wat range???then nly v can tel u wats better
Enjoy~!
No Pain...No Gain
speedyguy is offline
Old 01-03-2008, 08:55 PM   #13 (permalink)
Elevating Humanity
The Conqueror's Avatar
Intel
Regards,
The Conqueror
The Conqueror is offline
Old 03-03-2008, 10:47 AM   #14 (permalink)
Fullbring
Zangetsu's Avatar
I m not asking 4 purchase.....i just wanted 2 know (4 my knowledge)
the whole series of AMD proc (i.e the order,like which is the l8est& which is old)
dats it.......
Zangetsu is offline
Intel core duo t2450 @2 Ghz or intel dual core @ 1.73Ghz ??????????? arunks CPU / Motherboards 6 04-03-2008 11:54 PM
AMD SELLS INTEL CPUs... HAS IT COMPLETELY LOST THE WAR WITH INTEL C2D vish786 Technology News 9 09-06-2007 07:46 AM
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
Which is best.--->Intel 915P or Intel 915G vps85 CPU / Motherboards 5 20-01-2005 08:57 PM
- by c4u
