Hi all,
I have a Iball 1gb pendrive. My proble is that i can not keep any files into it.
when i try to copy/cut any file/folder from my hard disk and try to paste
it inside the pendrive, it is showing a "Can not copy<file/folder name>: The disk is write protected" and "Remove the write protection or use another disk".
I do not remember if i had made this one write protected or not. Please suggest me what to do. This is a new pen drive and i had never kept files/folders inside it.
Please suggest me how to remove the write protected option
