Old 29-02-2008, 08:41 PM   #1 (permalink)
Post Wifi Router for PC that would work with Macbook Pro
I don't have much knowledge of networking n stuff, just connected my Macbook Pro to my PC through Ethernet few times.
Now, I am looking for a Wifi Router for my PC so that I can access files and internet through my Macbook Pro. I would like some recommendations for a suitable Wifi Router.
Also, anything that I would keep in mind, Price etc. should be appreciated.
Thanks.
Me - Gone :(
sr_ultimate is offline
Old 04-03-2008, 11:54 AM   #2 (permalink)
aryayush's Avatar
Default Re: Wifi Router for PC that would work with Macbook Pro
If price isn't much of an issue, you can buy yourself an AirPort Extreme base station from Apple. It costs around Rs. 9,000.
If that's too expensive, there are several cheaper routers out there. I use a Netgear WGR614 myself. It cost me Rs. 2,000.
Any router you like, basically. They'll all work with your Mac right out of the box. Don't worry.
Enjoy.
aryayush is offline
Wanted Tutorial on how to use ur lappy as wifi router? INS-ANI Tutorials 3 16-02-2008 09:41 PM
Not able to ping Wifi router jamesbond007 Networking 17 26-11-2007 03:28 PM
will apple macbook work in indian heat conditions kaushiklingam QnA (read only) 13 19-09-2006 12:01 AM
- by c4u
