Old 29-02-2008, 07:47 AM   #1 (permalink)
ayushman9's Avatar
Question what is mean by 1066 (O.C) ?
I have a pc based on c2d e4400 onboard P5B-MX/WIFI-AP . When i had bought it my vendor had said that this is Intel quad ready but upto 1066 MHz .However later when i saw the specs it said 1066 Mhz(O.C) .Now i want to buy a C2D extreme or C2Q of 1066 MHz fsb ,the vendor is saying that the processor will run fine but you have to overclock it.
What is this overclocking .Will it damage my Pc .If i can't upgrade to quad then what will be the best alternative considering i keep my motherboard ,as i am unable to buy a ne mobo upto december due to budjet constraint.
There is No Dark & Light side of Force . There always has been,always will be & always has been,One & Only Ayushman
ayushman9 is offline
Old 29-02-2008, 10:43 PM   #2 (permalink)
moshel's Avatar
Default Re: what is mean by 1066 (O.C) ?
i suppose only a bios upgrade should do the trick for you..however even a bios upgrade is very risky...
http://support.asus.com/cpusupport/c...P5B-MX/WIFI-AP
moreover, pls tell us what is ur purpose of upgrading...if its for games then better spend on a graphics card.
moshel is offline
Old 01-03-2008, 01:09 AM   #3 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
No its not!
Now days motherboards come up with BIOS upgrading utilities from windows itself.
U just need to install the program and connect to internet and it will automatically update ur BIOS.
keith_j_snyder2 is offline
Old 01-03-2008, 09:51 AM   #4 (permalink)
ayushman9's Avatar
Arrow Re: what is mean by 1066 (O.C) ?
Let start by testing ,say i want to overclock e 4400 from 2,0 ghz to more ,how should i start
Old 02-03-2008, 01:36 AM   #5 (permalink)
moshel's Avatar
Start Here!
http://www.pcstats.com/articleview.c...id=1804&page=2
moshel is offline
Old 02-03-2008, 01:47 AM   #6 (permalink)
The Smaller Bang
MetalheadGautham's Avatar
1. which motherboard do you have ?
2. why do you want C2D Extreme ? Its a white elephant. Better go for a C2Q instead.
Apple iPad 2 16GB WiFi
MetalheadGautham is offline
Old 02-03-2008, 11:16 AM   #7 (permalink)
At Hell's Disq
hellgate's Avatar
read his 1st post carefully the mobo is mentioned there.
hellgate is offline
Max 1066 FSB product ayushman9 Hardware Q&A 3 27-02-2008 07:52 AM
Core 2 Duo - 1066 MHz - budget =7k s18000rpm Hardware Q&A 52 05-01-2008 11:25 AM
AM2 to use DDRII 1066? Kniwor QnA (read only) 5 10-04-2006 10:11 PM
- by c4u
